Engine Dies? #1220018
04/21/12 08:02 PM
04/21/12 08:02 PM
Wisconsin
70hemi4spdbee Offline OP
Wisconsin
Just assembled a 70 Roadrunner. Engine dies after a few miles. Let it set for a few minutes and fires back up Checked fuel, ruled it out. Its not fuel so it must be electrical. Installed an MSD Digital 6 box. When it dies there is a smell (exhaust) associatd with an out of time engine. Running an MSD Blaster 2 coil and the ballast resitor is still in place. As a matter of fact the MSD box draws its "on signal" (red wire) from the hot side of the ballast. Really perplexing. Anyone have an idea?
Re: Engine Dies? [Re: 70hemi4spdbee] #1220019
04/21/12 08:10 PM
04/21/12 08:10 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
the small red wire should not go through the ballast. you also don't need the ballast (unless you still have points).
