Dana 60 Carrier Bearing - Any differences?? #1219576
04/21/12 01:52 AM
04/21/12 01:52 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
I need to get a set of carrier bearings to install a new locker into the Dana 60
Is there any difference in bearings
Ratech
Strange
others?
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: Dana 60 Carrier Bearing - Any differences?? [Re: Kam*Kuda] #1219577
04/21/12 02:07 AM
04/21/12 02:07 AM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
Make sure the bearing is made by Timkin and you are good to go! Koyo are low budget.
Re: Dana 60 Carrier Bearing - Any differences?? [Re: Kam*Kuda] #1219578
04/21/12 09:07 AM
04/21/12 09:07 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
i just took my gears out if you want me to look at the pn# on the bearing for ya.
Re: Dana 60 Carrier Bearing - Any differences?? [Re: Clanton] #1219579
04/21/12 01:48 PM
04/21/12 01:48 PM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: Dana 60 Carrier Bearing - Any differences?? [Re: MRMOPAR] #1219580
04/21/12 05:10 PM
04/21/12 05:10 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
The standard Dana 60 uses the same carrier bearing with the exception of the Strange Dana-S series which uses a 382A race instead of the 382S.The 382A allows for the needed clearence for the adjusters on the S-series.
Re: Dana 60 Carrier Bearing - Any differences?? [Re: Kam*Kuda] #1219581
04/21/12 05:41 PM
04/21/12 05:41 PM
NC
440Jim Offline
440Jim  Offline
NC
Dana 60 bearings(cone)/races(cup)
Description (Cup / Cone), , , , , , ,,,, ID(in), OD(in), Width
Pinion(large) HM803110/HM803146, 1.625, 3.500, 1.187
Pinion(small) HM88510 / HM88542 , 1.250, 2.875, 1.563
Spool sides 382S / 387A, , , , , , ,,,, 2.250, 3.8125, 1.656
