I just installed an Innovate LC-1 and Digital gauge in the 68`.
It is unreadable.
The numbers jump/change faster than you can read them.
Imagine the .010-second column of a digital stop-watch. Its that fast.
Looks like 11 to 15 swing.
Called Innovate and he said " at idle and cruise thats normal,it will only be accurate at full load and throttle. Take it to the track and see".
Ok,so i took it out and made a dragstrip run up a LONG steep road SAME issue . Numbers allover the map changing constantly every split second.
It is totally un-useable like this.
The 02 sensor is in the X-pipe.
What if I moved it further back?
