Digital WideBand 02 Problem #1219456
04/21/12 12:09 AM
04/21/12 12:09 AM
N.E. Ohio
6bblFLASH Offline OP
N.E. Ohio
I just installed an Innovate LC-1 and Digital gauge in the 68`.
It is unreadable.
The numbers jump/change faster than you can read them.
Imagine the .010-second column of a digital stop-watch. Its that fast.
Looks like 11 to 15 swing.
Called Innovate and he said " at idle and cruise thats normal,it will only be accurate at full load and throttle. Take it to the track and see".
Ok,so i took it out and made a dragstrip run up a LONG steep road SAME issue . Numbers allover the map changing constantly every split second.
It is totally un-useable like this.
The 02 sensor is in the X-pipe.
What if I moved it further back?
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Digital WideBand 02 Problem [Re: 6bblFLASH] #1219457
04/21/12 12:12 AM
04/21/12 12:12 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I would think closer the exaust manifold
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Digital WideBand 02 Problem [Re: 6bblFLASH] #1219458
04/21/12 12:30 AM
04/21/12 12:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Its not gonna matter much at all... chassis dyno's
stick it about a foot into the tail pipe but most
dont run 3 points after the decimal point.... my
LM-1 works fine and you can watch it... I still want
the recorder for it
Re: Digital WideBand 02 Problem [Re: MR_P_BODY] #1219459
04/21/12 01:01 AM
04/21/12 01:01 AM
PA
moparacer Offline
moparacer  Offline
PA
Have you looked to see if there is a firmware upgrade for it?
My Lm-2 was unusable until I noticed the firmware version on Innovates site was newer then what mine was.
I flashed it and it works pretty good now. Not perfect, but it works.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Digital WideBand 02 Problem [Re: 6bblFLASH] #1219460
04/21/12 01:03 AM
04/21/12 01:03 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I have the sensor in my 69 Bee street car installed in the X-pipe and it reads steady, at idle, cruse and under max power. The sensor on the race car is located in the collector pipe before the turn out. It also reads steady under all conditions, idle, driving in the pits and max load. I think you may have something else going on.
Re: Digital WideBand 02 Problem [Re: Dabee] #1219461
04/21/12 02:23 AM
04/21/12 02:23 AM
wine country
8
8urvette Offline
8urvette  Offline
wine country
I HAD THE SAME ISSUE with lc-1, i pulled it did a fresh open air calibration and it solved the problem... i was also told, that if u have exhaust leaks upstream to the sensor it will cause it to jump like u described.
Re: Digital WideBand 02 Problem [Re: 6bblFLASH] #1219462
04/21/12 07:52 AM
04/21/12 07:52 AM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
i had jumpy numbers on an LM1 before i wired it directly to the battery.
Re: Digital WideBand 02 Problem [Re: VanishPt] #1219463
04/22/12 06:19 PM
04/22/12 06:19 PM
Calgary, Alberta
Turbo392 Offline
Turbo392  Offline
Calgary, Alberta
You can also adjust the sample rate if you want to read the numbers easier.
2003 Dodge Ram 1500 Turbo / Meth Injected 6.4L Hemi (392)
Re: Digital WideBand 02 Problem [Re: Turbo392] #1219464
04/22/12 08:15 PM
04/22/12 08:15 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
my friend had a LM-1 and he had to send it back 2 times to gewt it "fixed". i think the LM-1s are not the best choice and thier tech support is lacking. i have a wego3 and for the 430 bucks it comes with everything.
a data logger that goes to .1sec to 2 sec for about 7 min to 2 hours of recording.
it has a live display built in with out paying extra.
it has a spare 0 to 5vdc input for a extra input to watch.
and it is the size of a credit card.
they answered e mails on saturday and sunday when i asked scaling the 0 to 5vdc input.
he sold the lm-1 on ebay and got a wego3. no looking back at that big black brick.
good luck with the LM-1. i know they must work but i know some that had bad luck with them.
Re: Digital WideBand 02 Problem [Re: dmking] #1219465
04/23/12 11:43 AM
04/23/12 11:43 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
I have an LM-1 and the sensor is just behind the header in the pipe. I changed the seting to sample a little less frequently. My number are very readable.
Re: Digital WideBand 02 Problem [Re: babarracuda] #1219466
04/23/12 07:08 PM
04/23/12 07:08 PM
N.E. Ohio
N.E. Ohio
Ok,thanks for the help.
Wired it direct to the battery and re-did the fresh air calibration.
May have slowed it alittle,but still way too fast.
Even tried it with the alternator unhooked to see if it was electric noise or something. Nope.
Once you shut off the engine it reads 12.3
So it works,just too sensitive.
So I ordered an adapter cable so I can use a laptop and slow down the responce time.
