Re: girdle install question
[Re: 8urvette]
#1219310
04/20/12 08:48 PM
04/20/12 08:48 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
i used rtv under the girdle the gasket will rais it too much.i believe the gap at tha pan rail will be .003 or less.
[Re: 8urvette]
#1219311
04/20/12 10:17 PM
04/20/12 10:17 PM
Posts: 475 HEMPSTEAD TX
CUUDAK
HEMPSTEAD TX
I used the gray sealer on my girdle between the block. I can't stop the seepage!!
SRT8 CHARGER "Four door bore" <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
[Re: CUUDAK]
#1219312
04/20/12 10:57 PM
04/20/12 10:57 PM
Clanton
northern,Ohio,USA
once it leaks it has made a path and has to be redone.i use ultra copper but not that it matters.[ultra or 100% silicone clear]i found that useualy the tuneup made it leak so check yours from ring blowby,timing or fuel.
[Re: Clanton]
#1219313
04/21/12 12:14 AM
04/21/12 12:14 AM
Posts: 916 Arizona
Chucklehead
Arizona
You might try Yahmabond or a similar crankcase sealer that hey use on motorcycle engines. On my big stroker Harley I had to go with that instead of base gasket for the cylinders. To much pressure would blow the base gasket out. A Harley race engine builder told me to use the Yamhabond, no more leaks or gasket blow out.
Still Broke
[Re: Bill MeLater]
#1219315
04/21/12 12:40 AM
04/21/12 12:40 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
The Right Stuff will seal it... as for instructions, Hughes Engines has a nice tech article on there web site.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: rowin4]
#1219318
04/21/12 02:33 AM
04/21/12 02:33 AM
Posts: 781 wine country
8urvette
wine country
i bought it a few years ago i want to say i spent 300-400 on it, and its black colored..... It also came with ARP fasteners... i do have to shim , but have no idea what to take the nuts to on the girdle itself.
[Re: Clanton]
#1219323
04/22/12 02:39 AM
04/22/12 02:39 AM
CUUDAK
HEMPSTEAD TX
Hope its not blow-by! I just put this engine together. I still need to set the timing. My return from the turbo runs into the stock fuel pump location. The girdle seems to be a bit higher than the oil pan would have been. After I installed the timing cover I neglected to double check the dowl pin on the passenger side and the cover nippled out a bit below the dowl. I am assuming that with the turbo return flowing a large amount of oil to the area beside the timing chain therefore flooding it with oil making it come out more?? I gotta get the timing cover off and correct that leak then see if the girdle is still seeping. It may be the oil running down the pan rail from the cooling fan blowing it to the rear.
