Page 1 of 4 1 2 3 4
School me on overdrive transmissions for a RB #1219163
04/20/12 05:54 PM
04/20/12 05:54 PM
Delray beach, Florida
P
Performance Only Offline OP
P
which OD trans would be best behind a 500" RB in a E-body, street driven only car. the current combo is 600 HP.
gearvendors is out, so please don't go there.
machine shop owner and engine builder
Re: School me on overdrive transmissions for a RB [Re: Performance Only] #1219164
04/20/12 06:20 PM
04/20/12 06:20 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Passon gearset in an 833 case, until he is in production of his 5 speed its the next best thing because you dont have to cut/chop anything. Tim
Re: School me on overdrive transmissions for a RB [Re: astjp2] #1219165
04/20/12 06:39 PM
04/20/12 06:39 PM
Home of the Bluegrass
MoparJunkie Offline
MoparJunkie  Offline
I'm in the same boat... already revamping the cam selection and distributor curving to match my 505 with an overdrive 5 speed. Renovation started last week... next is the wait for the trans... It will be worth it! Patiently waiting Jamie...
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: School me on overdrive transmissions for a RB [Re: Performance Only] #1219166
04/20/12 07:02 PM
04/20/12 07:02 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Auto or manual
Re: School me on overdrive transmissions for a RB [Re: HotRodDave] #1219167
04/20/12 07:08 PM
04/20/12 07:08 PM
dogdays Offline
dogdays  Offline
4L80E with an Ultrabell. It's a very stout transmission and well-known in the HP aftermarket. Standalone controllers have been on the market for years.
R.
Re: School me on overdrive transmissions for a RB [Re: Performance Only] #1219168
04/20/12 08:54 PM
04/20/12 08:54 PM
AndyF Online content
AndyF  Online Content
I covered all the known options in my B-body book. Bottom line is that it depends if you're willing to cut the floor or not. If you're willing to cut the floor and the tranny crossmember then the options go way up.
Re: School me on overdrive transmissions for a RB [Re: AndyF] #1219169
04/20/12 08:58 PM
04/20/12 08:58 PM
P
P
this needs to be an auto trans. i'm not willing to cut the floor up on a 70 E body convertible. changing the crossmember is no big deal though.
does the 4L80 fit without cutting the floor?
Re: School me on overdrive transmissions for a RB [Re: Performance Only] #1219170
04/20/12 11:56 PM
04/20/12 11:56 PM
I don't think so. I've seen pictures of a handful of swaps and in every case the person needed to cut the floor to remove the tranny crossmember. That crossmember is a big deal in a Mopar since that is where the torsion bar anchors are. Some guys go with a coil over suspension to get rid of the torsion bars, other guys build a new crossmember.
I did see some posts by a guy who said that he did it without cutting the floor, but I think what he did was lower the engine and/or put the tranny in at a weird angle.
Eberg just did this swap in Mopar Action. Check out the pictures in the back issues. They cut the floor and did a fair amount of fab work.
The Keisler OD auto is supposed to fit without any cutting. I'm sure there are some guys on the board with that kit installed. Maybe someone will weigh in with some feedback.
Re: School me on overdrive transmissions for a RB [Re: AndyF] #1219171
04/21/12 12:57 AM
04/21/12 12:57 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Then really your only option is a GM 700R4. The Keisler auto is based on the GM 4l60-e, which is the electronic version of the 700R4. It will take a well built 700R4/4l60-e to take 600hp but it can be done.
Re: School me on overdrive transmissions for a RB [Re: Performance Only] #1219172
04/21/12 01:58 AM
04/21/12 01:58 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
4l80E will need the floor cut.
GV is a good option here. Why is it out of the picture(just curious)? I do a lot of GV conversions and currently finishing one up on a 70 Charger R/T. Everyone who I have installed one of these units on has been VERY happy. They are trouble free, and can handle a fair amount of power. B/E cars require very little floor massaging(no cutting), but admittedly I have never done one on a convert so I cant attest to the fitment there.
Otherwise, your options are very limited if no floor cutting is mandatory. What I gave done on some that the floor needed cutting, I simply cut a clean section out and fabbed another replacement floor piece that raises the roof on the floorboards, so to speak. The piece is cut cleany out and can easily be buttwelded back in and with a bit of bodywork can be made to look 100% perfect when done.
Let me know if you want any photos of the installation in the Charger. Car is just about ready to get off the lift.
MB
Re: School me on overdrive transmissions for a RB [Re: Performance Only] #1219173
04/21/12 12:33 PM
04/21/12 12:33 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
As mentioned, Keisler's 4L60 will basically bolt in, but 600 ft/lbs is max-max.
6-speed version of 4L80 (TCI 6X) is awesome beyond belief, but a lot of hacking required; as Andy mentioned, I wrote it all up in macro detail.
Both of these keep propshaft / u-joint angles better than stock, and there's no unsupported cantilevered housing dangling out there as with GV. And the programability, converter lock, etc., places them in a class alone.
Rick
Re: School me on overdrive transmissions for a RB [Re: Rick_Ehrenberg] #1219174
04/21/12 11:55 PM
04/21/12 11:55 PM
Escondido, CA
kick_the_reverb Offline
Escondido, CA
Dan,
This is something less popular on Mopars, but maybe try talking to these two 200R4 specialists:
Lonnie Diers at Extreme Automatics
Or
Dave Husek at TURBO BUICK PERFORMANCE
The 200R4 has a lot of following in Turbo Buick circles, and can be built to take a lot. Built right it can be much stronger than any 700R4 and its derivatives (4L60E).
It's a very compact transmission. If there's an adapter plate for BBM to GM transmissions, then I am pretty sure it can be done with no floor hacking.
It would probably be much cheaper than Keisler.
Good luck,
Ran
"Hey mister, something's wrong with your car, it idles roughly" - number one comment I got in Israel when daily driving a 70 Barracuda with a lopey cam.
Currently working on - 1966 Dodge A100 van 318/auto
Finally - disc brakes on the front.
In the plans - rear disc brakes, B&M 250 blower
Re: School me on overdrive transmissions for a RB [Re: kick_the_reverb] #1219175
04/22/12 02:45 AM
04/22/12 02:45 AM
Manitoba, Canada
Manitoba, Canada
The 700R4 guys say theirs is better than the 200-4R. The 200-4R guys say theirs is better than the 700R4. What I've read makes it sound like they both start crapping out at around the same hp levels.
Re: School me on overdrive transmissions for a RB [Re: DaytonaTurbo] #1219176
04/22/12 03:36 AM
04/22/12 03:36 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Yeah... about 300hp and a little bit of traction
Re: School me on overdrive transmissions for a RB [Re: GTX MATT] #1219177
04/22/12 10:46 AM
04/22/12 10:46 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
1wildRT put a 5/18 in an ebody vert without cutting the floor , there are pictures somewhere. the only real issue is controlling od and possibly lockup , can be done with pressure and vac switch with the mechanical gov version , but the electronic gov trans is a little better to deal with.
i don't think there is a stand alone controller for one yet , if there is it would be cheaper to buy a Z06 corvette ..
Re: School me on overdrive transmissions for a RB [Re: GTX MATT] #1219178
04/22/12 10:50 AM
04/22/12 10:50 AM
colorado
savoy64 Offline
savoy64  Offline
colorado
before you get into an ultra bell to put a chev tranny in----consider the 618---it is quite strong and lives behind a cummins or V10 motor and they can be built up for those 1000+ hp trucks--before anyone starts whining about the build cost--the chev units will have to be built too-the early ones are hydraulic valve body and simple to work with---bob
Re: School me on overdrive transmissions for a RB [Re: savoy64] #1219179
04/22/12 10:58 AM
04/22/12 10:58 AM
GA
roadrunninMark Offline
GA
You can usa a 518, no floor cutting. Check here at cuda-challnger: http://www.cuda-challenger.com/cc/index.php?topic=23678.0
In the Moparts archive is a member you put it behind a big block with the ultra bell, don't have a link off hand.
For the trans mount, US Car Tool told me they make it so you can get it from them.
Member Whoosewhatzit, (something like that) was thinking of making a electronic controller for the 96 and up 518s, otherwise you need a 94-95 (best for lock up convertor), or real earlier non lockup (handles more HP, but will need a few mods). You then need a few more items like someone else said for the OD and such.
Re: School me on overdrive transmissions for a RB [Re: GTX MATT] #1219180
04/22/12 04:57 PM
04/22/12 04:57 PM
Escondido, CA
Escondido, CA
Stock GM trannys are as you describe. But there has been a lot of development from the aftermarket.
I am not aware of anyone claiming built 700R4 types can handle more than 200R4.
4L80E (and the TCI 6 pseed) are beefy but huge, so they are out of the question.
I am all for keeping cars as Mopar as possible. But sometimes the 518/618 solution does not fit the vehicle. Mopar chose to take a 727 and stick an OD unit on the end of it. The GM trannys have more compact dimensions because they are designed differently.
Ran
Re: School me on overdrive transmissions for a RB [Re: kick_the_reverb] #1219181
04/22/12 06:54 PM
04/22/12 06:54 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
Yep. I take a built 200-4R over a built 727 with a GV unit any day of the week. I think some here would be shocked at the amount of HP the 200 can take when built properly. At a much reduced weight to boot. Win, win.
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: School me on overdrive transmissions for a RB [Re: Performance Only] #1219182
04/22/12 08:54 PM
04/22/12 08:54 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Not many automatic options unless you cut the torsen bar crossmember out of the trans tunnel?
Keisler claims no cutting required for their kit, so it might work? Their stage 3 kit is "rated" at 650 lb-ft.
Page 1 of 4 1 2 3 4
