Tremick TR6060 behind a 360? #1218981
04/19/12 11:58 PM
04/19/12 11:58 PM
MO, USA
The Dodge Guy Offline OP
MO, USA
Has anyone put a Tremick TR6060 behind a 360 yet? I found one that I am thinking about buying if there is a way to put it behind a 360. Any help would be great. Thanks Moparts.
Re: Tremick TR6060 behind a 360? [Re: The Dodge Guy] #1218982
04/20/12 12:31 AM
04/20/12 12:31 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The TR6060 is a piss poor "upgrade" of the T-56, too many issues with 1-2 shift syncros, and 3-4 shift fork breakage...IMHO your better off looking for a Viper T-56 6 spd as it will have better internals, avoid the GM t-56 as it has a weak input shaft and is only good for about 450 HP max before breakage,..the Viper T-56 is good for up to 800HP, there's plenty of aftermarket suppliers offering everything from trannys to install kits for the T-56
Mike
Re: Tremick TR6060 behind a 360? [Re: DAYCLONA] #1218983
04/20/12 01:47 AM
04/20/12 01:47 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I thought it was the output shaft on the GM T56's that was weak? If memory serves a popular upgrade is to convert them to viper or chevy ssr output shafts.
Re: Tremick TR6060 behind a 360? [Re: The Dodge Guy] #1218984
04/20/12 04:43 AM
04/20/12 04:43 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Call Paul at Liberty for the straight scoop on the different transmissions. He's a pretty knowledgeable guy and a straight shooter. Libertys # is 313-278-4040
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Tremick TR6060 behind a 360? [Re: DaytonaTurbo] #1218985
04/20/12 01:06 PM
04/20/12 01:06 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Your correct, Thanks, meant to type output, and yes a popular upgrade is the larger Viper output shaft
Re: Tremick TR6060 behind a 360? [Re: The Dodge Guy] #1218986
04/21/12 06:12 PM
04/21/12 06:12 PM
QLD Australia
Keith Black® Offline
QLD Australia
QuickTime make the bell housing . Go the T56 Magnum route.
Darren Beale
Keith Black Racing Engines®
