Re: WHAT IS THE AVERAGE COST TO BALANCE
[Re: runner12]
#1218900
04/19/12 09:55 PM
04/19/12 09:55 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
$150 is a cheap balance job, especially if they used race type tolerances. Maybe they got lucky and the rods and pistons all were almost dead nuts out fo the box, which I have never seen... Like Cab says, it must have needed mallory metal. BTW, a typical shop would charge $175 - $250 for a balnce job that didnt need mallory metal. I just saw a 700" T/S BBC at a shop where the mallory metal flew out of the crank on a dyno pull. It wasnt installed as it should have been. You want the shop to be competent.A good balance job is worth every penny.
RIP Monte Smith
[Re: CompWedgeEngines]
#1218906
04/20/12 11:23 AM
04/20/12 11:23 AM
Posts: 16,928 NC
440Jim
NC
[Re: runner12]
#1218907
04/20/12 11:25 AM
04/20/12 11:25 AM
Posts: 16,928 NC
440Jim
NC
Thanks! after looking at the bill they added mallory and machined the counter weights??? This is a OHIO crank < I called and ask some questions and was told they never charge that much and the cranks are not that far out???
Hard to tell from here, but it looks like they took too much off the counterweights, and that caused the need for mallory. I have heard of this on 4.15 cranks before. If they left the counterweights alone, it shouldn't need the heavy metal.
[Re: runner12]
#1218910
04/20/12 07:31 PM
04/20/12 07:31 PM
Posts: 6,566 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Does anyone have a idea of the cost of a balance job?? I had a 500ci 440 balanced last year for $150.00 this year it was $406.00 HELP!!!!
$150??? That's like 2 hrs of shop time and I don't want any part of a 2 hour balance job. To do the job right takes TIME and time costs MONEY. $400 is reasonable if the job is done right IMHO.
Kevin
