My wife's Dakota (1995, Extended Cab, 3.9L V6) has developed a strange problem.
Periodically, when the door is opened, the dash and parking lights will flash about 8 times. The flashes are always at a regular interval.
When this happens the engine will not crank using the key. I've had to connect a push button to the starter solenoid so it can be started when it happens.
I've searched the Internet but haven't been able to find an answer.
Any ideas?
Thanks,
Duane
