Re: 3/8" to 1/2" OIL PICK-UP TUBE...AND BLOCK MOD?
[Re: Labratt]
#1218538
04/19/12 12:16 AM
04/19/12 12:16 AM
Posts: 52,972 Romeo MI
MR_P_BODY
JMO Randy.... nope... you arent spinning high enough and its too easy to crack out(it gets real thin in the boss area)and if you do crack it out... then its a external pick up.......... again... JMO ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Labratt]
#1218539
04/19/12 12:20 AM
04/19/12 12:20 AM
Posts: 2,527 PA
moparacer
PA
I have spun my 500ci 7400 at times with a 3/8 pickup and never had any issues.
That area looked way to thin for me to try drilling it and tapping it.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: Labratt]
#1218541
04/19/12 12:27 AM
04/19/12 12:27 AM
MR_P_BODY
Thanks for that info,Mike! I definately don't want to crack the block....and have to spend MORE money on an external set-up! This project is already setting me back a pretty penny!
I hear ya.... stop on by.... I have a few Blues for ya... LOL ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Labratt]
#1218545
04/19/12 10:58 AM
04/19/12 10:58 AM
Posts: 17,913 S.E. Michigan
ZIPPY
S.E. Michigan
If by "block mod" you mean smoothing out the hard 90 degree turn the oil makes right after entering the block, I would say definitely do that. It is a 10 minute deal and costs nothing if you already have the tools. I don't think increasing the oil pickup to 1/2 is necessary, but it does not do any harm unless the procedure is messed up. At that point it does a whole bunch of harm ![](/ubbthreads/images/graemlins/shruggy.gif) I would never do it to one that looked thin to begin with. So if there are any second thoughts, don't do it ![](/ubbthreads/images/graemlins/Twocents.gif)
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#1218547
04/19/12 11:46 AM
04/19/12 11:46 AM
Posts: 4,101 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
I don't think increasing the oil pickup to 1/2 is necessary, but it does not do any harm unless the procedure is messed up. At that point it does a whole bunch of harm I would never do it to one that looked thin to begin with. So if there are any second thoughts, don't do it
Yes X2 with Rich...leave it at 3/8" NPT but, using the 1/2" pipe tube. And get in the block with a carbide and radius the intersecting passages. I'd also ream the oil passages to the mains...I think it's a 17/64" ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: HardcoreB]
#1218548
04/19/12 11:58 AM
04/19/12 11:58 AM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
This post makes me feel alot better about my 3/8 pickup. I dont rev it past 6500. It seems to run about the same if I shift at 6800 or 6300 so I figured I might as well keep the r's down and save on the engine a little.
67' charger 499 RB
10.57 at 127
[Re: 383man]
#1218550
04/19/12 12:52 PM
04/19/12 12:52 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Here is another thing that hasn't been mentioned yet, but is very important to note. The 1/2" pickup mod will/may limit your choices when going to a longer stroke. The boss(even with 2.200 rod pin) needs to be clipped to clear the rod big end with stroker setups. Plus now you have a larger diameter tube to contend with. Measure twice/cut once. ![](/ubbthreads/images/graemlins/hammer.gif) MB
[Re: viperblue72]
#1218553
04/19/12 05:26 PM
04/19/12 05:26 PM
MR_P_BODY
I don't really understand why it is necessary to begin with. Fluid can only flow as much as the smallest bottleneck. So rather you have a 20oz pepsi, or a 2qt pepsi bottle, it's gonna flow out the end of the bottle at the same rate. Maybe someone will correct me if I am wrong about my theory.
This is on the suction side... you ALWAYS try to have a larger inlet to your pump... REMEMBER... pumps dont suck... its still atmospheric pressure pushing the oil in.. all the pump does is create the negative pressure zone so the oil can get pushed in.... no difference than the intake and pistons(piston creates the negative so atmospheric pressure can push in the air/fuel ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Labratt]
#1218554
04/19/12 07:34 PM
04/19/12 07:34 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Good deal Randy ![](/ubbthreads/images/graemlins/thumbs.gif) lots of 9 second cars out there with internal 3/8's pickups. I just spent about an hour smoothing the passages in the pump and pick-up passages on my engine ![](/ubbthreads/images/graemlins/Twocents.gif) Make sure you spend some time with a dremmel or die grinder on your oil pump ![](/ubbthreads/images/graemlins/thumbs.gif) Gus ![](/ubbthreads/images/graemlins/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Labratt]
#1218555
04/19/12 07:42 PM
04/19/12 07:42 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
3/8th's on all of our engines..we don't go past 65-6800,so we don't feel the mod is needed.Never have had any bearing or oil related issues.
