3/8" to 1/2" OIL PICK-UP TUBE...AND BLOCK MOD? #1218537
04/19/12 12:11 AM
04/19/12 12:11 AM
Clinton Twp... north of Deetro...
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Is this change worth doing on a 6500rpm 440? My block is at the machine shop,and I thought this would be a worthy upgrade. Chuck Senatore states in his book that it is. What are your opinions? Thanks,fella's! Randy B.
Re: 3/8" to 1/2" OIL PICK-UP TUBE...AND BLOCK MOD? [Re: Labratt] #1218538
04/19/12 12:16 AM
04/19/12 12:16 AM
MR_P_BODY Offline
MR_P_BODY  Offline
JMO Randy.... nope... you arent spinning high enough
and its too easy to crack out(it gets real thin in
the boss area)and if you do crack it out... then its
a external pick up.......... again... JMO
Re: 3/8" to 1/2" OIL PICK-UP TUBE...AND BLOCK MOD? [Re: Labratt] #1218539
04/19/12 12:20 AM
04/19/12 12:20 AM
PA
moparacer Offline
moparacer  Offline
PA
I have spun my 500ci 7400 at times with a 3/8 pickup and never had any issues.
That area looked way to thin for me to try drilling it and tapping it.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: 3/8" to 1/2" OIL PICK-UP TUBE...AND BLOCK MOD? [Re: MR_P_BODY] #1218540
04/19/12 12:22 AM
04/19/12 12:22 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks for that info,Mike! I definately don't want to crack the block....and have to spend MORE money on an external set-up! This project is already setting me back a pretty penny!
Re: 3/8" to 1/2" OIL PICK-UP TUBE...AND BLOCK MOD? [Re: Labratt] #1218541
04/19/12 12:27 AM
04/19/12 12:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I hear ya.... stop on by.... I have a few Blues for ya... LOL
Re: 3/8" to 1/2" OIL PICK-UP TUBE...AND BLOCK MOD? [Re: MR_P_BODY] #1218542
04/19/12 12:40 AM
04/19/12 12:40 AM
Cab_Burge Online work
Cab_Burge  Online Work
Been there done that, external pickups can be a real pain I shift my 518 motor at or above 7000 RPM on every run, stock Mopar 440 6 pak 3/8 pickup and 6 quart oil pan
Re: 3/8" to 1/2" OIL PICK-UP TUBE...AND BLOCK MOD? [Re: MR_P_BODY] #1218543
04/19/12 12:43 AM
04/19/12 12:43 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
I just might take ya up on that! A FEW Blues are always welcome! I've been VERY BUSY lately,with packing up the house and all...but,I'll try to take a little break and stop by...SOON!
Re: 3/8" to 1/2" OIL PICK-UP TUBE...AND BLOCK MOD? [Re: Cab_Burge] #1218544
04/19/12 12:47 AM
04/19/12 12:47 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks for your opinion,Dahrl...Mr.Cab! Don't want to go the external route if I can help it!
Re: 3/8" to 1/2" OIL PICK-UP TUBE...AND BLOCK MOD? [Re: Labratt] #1218545
04/19/12 10:58 AM
04/19/12 10:58 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
If by "block mod" you mean smoothing out the hard 90 degree turn the oil makes right after entering the block, I would say definitely do that. It is a 10 minute deal and costs nothing if you already have the tools.
I don't think increasing the oil pickup to 1/2 is necessary, but it does not do any harm unless the procedure is messed up. At that point it does a whole bunch of harm I would never do it to one that looked thin to begin with. So if there are any second thoughts, don't do it
Rich H.
Esse Quam Videri
Re: 3/8" to 1/2" OIL PICK-UP TUBE...AND BLOCK MOD? [Re: Labratt] #1218546
04/19/12 11:08 AM
04/19/12 11:08 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Just another vote for leaving the 3/8" pickup. Not necessary. Built plenty with 3/8 pickups and no problems. One of the reasons why the Hemi got the 1/2 pickup was less about performance and rpm and more about the oil demands of feeding 4 rocker shatfs/stands. But what the hell do I know.
MB
Re: 3/8" to 1/2" OIL PICK-UP TUBE...AND BLOCK MOD? [Re: ZIPPY] #1218547
04/19/12 11:46 AM
04/19/12 11:46 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Yes X2 with Rich...leave it at 3/8" NPT but, using the 1/2" pipe tube. And get in the block with a carbide and radius the intersecting passages. I'd also ream the oil passages to the mains...I think it's a 17/64"
Re: 3/8" to 1/2" OIL PICK-UP TUBE...AND BLOCK MOD? [Re: HardcoreB] #1218548
04/19/12 11:58 AM
04/19/12 11:58 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
This post makes me feel alot better about my 3/8 pickup. I dont rev it past 6500. It seems to run about the same if I shift at 6800 or 6300 so I figured I might as well keep the r's down and save on the engine a little.
67' charger 499 RB 10.57 at 127
Re: 3/8" to 1/2" OIL PICK-UP TUBE...AND BLOCK MOD? [Re: dragram440] #1218549
04/19/12 12:25 PM
04/19/12 12:25 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I do agree 3/8 is fine for what you are doing Randy. But I did take mine to 1/2" since my brother has the right tools at his machine shop and my block looked fine for the mod. As long as it is done right it cant hurt at all and I dont mind feeling good about my oiling system and I have just got used to doing my blocks that look good. We started it years ago on my brothers low deck 400 block with B1 heads that he built back about 20 years ago. He twisted it pretty good and it ran 8.90's in his 2600 lb Cuda with a single carb on all motor. So we have just got used to doing it for extra precation. But I agree the 3/8 works fine for most bigblocks until it gets real serious. Ron
Re: 3/8" to 1/2" OIL PICK-UP TUBE...AND BLOCK MOD? [Re: 383man] #1218550
04/19/12 12:52 PM
04/19/12 12:52 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Here is another thing that hasn't been mentioned yet, but is very important to note.
The 1/2" pickup mod will/may limit your choices when going to a longer stroke. The boss(even with 2.200 rod pin) needs to be clipped to clear the rod big end with stroker setups. Plus now you have a larger diameter tube to contend with.
Measure twice/cut once.
MB
Re: 3/8" to 1/2" OIL PICK-UP TUBE...AND BLOCK MOD? [Re: HPMike] #1218551
04/19/12 05:04 PM
04/19/12 05:04 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I don't really understand why it is necessary to begin with. Fluid can only flow as much as the smallest bottleneck. So rather you have a 20oz pepsi, or a 2qt pepsi bottle, it's gonna flow out the end of the bottle at the same rate. Maybe someone will correct me if I am wrong about my theory.
Re: 3/8" to 1/2" OIL PICK-UP TUBE...AND BLOCK MOD? [Re: HPMike] #1218552
04/19/12 05:08 PM
04/19/12 05:08 PM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks EVERYONE,for your opinions! I told Sean this morning to leave it as is. After the last 6 yrs. of beating on this motor,the bearings....and ALL the other parts looked pretty darn good! Mr. P-Body can attest to that! My main concern was to strengthen the bottom end,and I think by going with ARP-studded, aluminum main caps..and h-beam rods,that should do it!
Re: 3/8" to 1/2" OIL PICK-UP TUBE...AND BLOCK MOD? [Re: viperblue72] #1218553
04/19/12 05:26 PM
04/19/12 05:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
This is on the suction side... you ALWAYS try to
have a larger inlet to your pump... REMEMBER...
pumps dont suck... its still atmospheric pressure
pushing the oil in.. all the pump does is create the
negative pressure zone so the oil can get pushed in....
no difference than the intake and pistons(piston creates
the negative so atmospheric pressure can push in
the air/fuel
Re: 3/8" to 1/2" OIL PICK-UP TUBE...AND BLOCK MOD? [Re: Labratt] #1218554
04/19/12 07:34 PM
04/19/12 07:34 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Good deal Randy lots of 9 second cars out there with internal 3/8's pickups.
I just spent about an hour smoothing the passages in the pump and pick-up passages on my engine
Make sure you spend some time with a dremmel or die grinder on your oil pump
Gus
64 Plymouth Savoy
Dana 60
Re: 3/8" to 1/2" OIL PICK-UP TUBE...AND BLOCK MOD? [Re: Labratt] #1218555
04/19/12 07:42 PM
04/19/12 07:42 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
3/8th's on all of our engines..we don't go past 65-6800,so we don't feel the mod is needed.Never have had any bearing or oil related issues.
Nautilus Racing-
Re: 3/8" to 1/2" OIL PICK-UP TUBE...AND BLOCK MOD? [Re: fourgearsavoy] #1218556
04/20/12 12:37 AM
04/20/12 12:37 AM
Labratt Offline OP
Good Ol Randy B!
Labratt  Offline OP
Good Ol Randy B!
Thanks guys! Gus..what do you suggest doing with the dremmel? I didn't notice any casting flash on my Melling HV63 pump! Should something on the pump be opened-up? Thanks! Randy
