Re: Fender tags
[Re: rtse70]
#121847
09/16/08 08:27 PM
09/16/08 08:27 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
This is the place I recommend to everyone wanting to get any documentation reproduced for their vehicles
GTS
Save your money and information. Go with A. G. Backeast. This is the guy that Galen sends your order to after he gets all the information from you concerning your car. Get the tag faster and cheaper without Galen as a middleman.
Re: Fender tags
[Re: Snoopy]
#121849
09/18/08 06:45 PM
09/18/08 06:45 PM
Snoopy
GTS
Update: I just requested a replacement tag for my car from A. G. Backeast and supplied them with pictures of part of my broadcast sheet, my original fender and dash VIN tag. They came back saying my original fender tag didn't look original and they wanted a full picture of my broadcast sheet, pictures of the VIN stampings on the radiator support, cowl, engine and transmission and door VIN decal.
I think that this might be a reasonable request if I wanted a replacement dash VIN tag, but it is over the top for a fender tag. I suspect he is mining for information to supply to Galen Govier.
How does a guy with only a dash VIN tag and radiator & cowl stampings get a fender tag made? BTW: I have all the information he requested, less the engine and trans stampings, neither is original to the car.
Has anyone else purchased fender tags from these people? What information did they want you to supply and what did you give them?
Re: Fender tags
[Re: Snoopy]
#121856
09/18/08 08:31 PM
09/18/08 08:31 PM
Posts: 5,268 NY
70440+6bbl
NY
Re: Fender tags
[Re: Snoopy]
#121860
09/19/08 12:41 PM
09/19/08 12:41 PM
Posts: 21,822 Kirkland, Washington
Pacnorthcuda
I wanted a replacement tag so I could put it on the car for shows and keep the original in a safe place. A couple of years ago a friend got his stolen off his car at a local show, I don't want to be in the same position.
On this note, when I heard that tags were being stolen at shows, I decided to replace the two screws with two phillips bolts (with the same size head), and nylocks on the under side. Even for my 'lowly' BS23N car.
A simple screw driver and 5 seconds isn't going to get my tag. Problem solved
Re: Fender tags
[Re: Pacnorthcuda]
#121861
09/19/08 12:47 PM
09/19/08 12:47 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
I was thinking that a blob of JB weld on the underside of mine would accomplish the same thing.
Cheers, Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
