Coil bracket with Holley carb #1218361
04/18/12 07:25 PM
04/18/12 07:25 PM
dark side of the moon
Dougsmopars Offline OP
Is there any brackets being made to keep the coil in the stock location with a Holley carb? The dual feed line is in the way and front bowl sticks out . Any aftermarket coil brackets to keep the coil in the stock location? Looking to keep it down flat like orignal to keep my stock air cleaner.
Re: Coil bracket with Holley carb [Re: Dougsmopars] #1218362
04/18/12 09:33 PM
04/18/12 09:33 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Try Fabulous Fabrications. 303-666-9882. or email
greg@fabulousfabrications.com
They used to advertize in Mopar Collectors Guide. he also makes the dual feed fuel lines for the Holleys.
I have both his coil relocation bracket & fuel lines on my car.
I had to modify his bracket a bit since re-installing my A/C setup & stock cast iron manifold but it still works.
This is a shot of it on my CH4B manifold
1MYTGTX
Re: Coil bracket with Holley carb [Re: 1MYTGTX] #1218363
04/18/12 09:35 PM
04/18/12 09:35 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Another shot with the A/C set up & stock manifold (modified from his original design)
1MYTGTX
Re: Coil bracket with Holley carb [Re: 1MYTGTX] #1218364
04/18/12 09:51 PM
04/18/12 09:51 PM
ALBERTA CANADA
CUDA8U Offline
CUDA8U  Offline
ALBERTA CANADA
i have a holley 850 and the fuel line runs well below the after market bottom "tray" that has a 14" element holley designed piece that is built to be lowered down for hood clearance and works good on an e-body with a factory hood,the fuel line runs between coil and distributor hooked to a braided line
Re: Coil bracket with Holley carb [Re: 1MYTGTX] #1218365
04/18/12 10:01 PM
04/18/12 10:01 PM
Thats just what i'm looking for. Thanks
Re: Coil bracket with Holley carb [Re: 1MYTGTX] #1218366
04/18/12 10:20 PM
04/18/12 10:20 PM
That email address is no good. I wrote to him at that address and got a reply from someone telling me they make window treatments not car parts
Re: Coil bracket with Holley carb [Re: 1MYTGTX] #1218367
04/18/12 10:36 PM
04/18/12 10:36 PM
Just called him. He answered the phone will have my line kit and coil relocate bracket to me in a week. Thanks again for the info.
Re: Coil bracket with Holley carb [Re: Dougsmopars] #1218368
04/19/12 05:30 PM
04/19/12 05:30 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
I used a coli bracket from a Ford on mine. It only uses on bolt instad of the two, and lets my coil clear the hard line to the carb.
1981 Dodge D150 360 auto
Re: Coil bracket with Holley carb [Re: Dougsmopars] #1218369
04/20/12 09:33 PM
04/20/12 09:33 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Good to hear he is still making the stuff....did you ask if he had an updated email address or just the phone # only??
1MYTGTX
Re: Coil bracket with Holley carb [Re: 1MYTGTX] #1218370
04/20/12 10:22 PM
04/20/12 10:22 PM
Phone number is the same. Sorry i didn't ask about an email address.
Re: Coil bracket with Holley carb [Re: Dougsmopars] #1218371
04/26/12 06:07 PM
04/26/12 06:07 PM
Parts came today. Excellent parts. Greg did a super job on the lines they look factory and the coil relocate plate is perfect. Price was very resonible. His email is sixpackbee@aol.com
