I have a prosystem 780 speced for my combo and victor intake. The heads were milled and ported pretty good.The intake was gasket matched with a little runner work.It has trick flow valve stems and Titatium valves,locks,5/16th stem. plus lots of work on the ehaust side. I think flows 280 or around there. I never got a copyof the info so forgive my memory.The assembley was balanced. I think we took off about 28 grams of rotating weight, It was done by a a friend who does a lot of top NMRA motors.I helped but did more of keeping the fridge full of beer.
It seems like the valve train is the week link in a SB mopar with stock style heads. So we lightend as much of the top as possable. But just want to see what guys are turning..Im feeling 7000 should be safe for a long time,, But when I get more track time, I will try the differnt rpm shift,etc, My first time out was rough. My set up was far from right.
I had a auto with only 3000 stall and a 5.13gear. So my 60'was 2.1-2.6
with a 13.02 best time at 102 mph. So I am now going 4.56 with a 4spd...
I also ran 275/15 st tires and spun from 4000-7000 rpm and ran out of motor 20 feet or so at 7000 rpm before 1/4
I am going to try a also using my 29/9 slicks next time out..
