9 inch Ford #1218034
04/17/12 10:34 PM
04/17/12 10:34 PM
Ohio, U.S.
73-Dart-sport Offline OP
Ohio, U.S.
What is the volume of gear fluid for this rear end?
Re: 9 inch Ford [Re: 73-Dart-sport] #1218035
04/17/12 10:38 PM
04/17/12 10:38 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
2 quarts
Re: 9 inch Ford [Re: ProSport] #1218036
04/17/12 11:47 PM
04/17/12 11:47 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
on mine i thought it was like 3. either way you know when to stop so it is what it is.
i use royal 70/140 or redline oil same extreem pressure oil and the gears are perfect.
Re: 9 inch Ford [Re: dmking] #1218037
04/18/12 07:07 AM
04/18/12 07:07 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I asked this same question a couple yrs ago and everyone including Monte Smith said 2 quarts.
Re: 9 inch Ford [Re: ProSport] #1218038
04/18/12 07:53 AM
04/18/12 07:53 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
depends on the set up doesn't it? i have 3 1/2 quarts in mine but i have floater hubs that need lube oil.
Re: 9 inch Ford [Re: 73-Dart-sport] #1218039
04/18/12 11:50 AM
04/18/12 11:50 AM
an8sec70cuda Offline
2 quarts is plenty for a normal street/strip rear.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 9 inch Ford [Re: ProSport] #1218040
04/18/12 12:40 PM
04/18/12 12:40 PM
ohio
dbran451 Offline
dbran451  Offline
ohio
Hey Bob you still lurking around hear I thought you went over to the dark side
