1971 Cuda NO TURN SIGNALS
#1218022
04/17/12 10:34 PM
04/17/12 10:34 PM
I was going to replace the turn signal switch because thyey were intermittantly working, now I notice when I turn the park lamps on the turn signal indicators on the cluster partially light. I dont have a wiring diagram for it. Any knowns or checks? No power to the flasher when they dont work. Any help appreciated!
Re: 1971 Cuda NO TURN SIGNALS
[Re: dynamite]
#1218024
04/18/12 12:06 AM
04/18/12 12:06 AM
I tried grounding the dash better with my power probe applying ground places it didnt seem to make a difference, tried an old t/s switch with no change
[Re: buildanother]
#1218026
04/18/12 08:21 AM
04/18/12 08:21 AM
When I went to bed last night I had no turn signals. When I woke up I had them. When I turn the park lights on, the indicators still light up, one brighter than the other. I used a remote ground and started touching dash areas, the front parking lamps, and the rear housings, no change.
#1218027
04/18/12 10:36 AM
04/18/12 10:36 AM
Could a un grounded or mis grounded front park lamp cause this issue??
#1218029
04/18/12 11:47 AM
04/18/12 11:47 AM
Posts: 1,506 Indiana
GrnMagic77
Peter Parker
Peter Parker
Indiana
I have dealt with this issue on my trucks.First off I made sure beyond a doubt that I had good grounds on signal/parking lights.Next I pulled the bulbs out of the side marker lights to see if it made a difference.In my case it definately did,my side marker clearance lights work through a less than sufficient backfeed system that causes problems when the bulbs are plugged in...I assume it may be the same for '71 E-bodies but don't know. Sounds mostly like you have a grounding issue somewhere since the problem is intermitent...perhaps this wiring diagram will be helpful.
1978 Round Up-1977 Warlock-1977 Powerwagon Adven.-
1976 Blue "Macho"-1974 Charger-1968 Fury III -1966 Newport *
[Re: Moonraker]
#1218032
04/18/12 12:00 PM
04/18/12 12:00 PM
Thanks for the help guys! I cant wait to get out of work to look at it again. I just bought the car and it had a rotisserie resto so I figured it was a ground through paint issue. Just cant find it, Like I mentioned I had a park lamp out but it worked while it was hanging and plugged in. I added the ground but just could have a poor test result throw me in circles. I'm used to new wiring diagrams and new technology!
#1218033
04/18/12 08:31 PM
04/18/12 08:31 PM
You guys are great! Bad front parking lamp housings, pigtails, and of course ground!
