High-Tech Parking Cables Lokar (DANA / Explorer disc ) #1217998
04/17/12 09:59 PM
04/17/12 09:59 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
I swapped in a new DANA 60 from DTS into my Challenger project. The rearend came with optional Ford Explorer disc brakes, which use cables completely different from the typical drum-brake style cables the factory rearend used. What to do? I found that Lokar Performance Products offers a set of high-tech parking cables made special for the Ford Explorer brakes. The problem is the way the cable hooks to the Foot Operated operated brake setup. Has any one else completed this swap? The way the cables are universal but appear to be more designed for a GM/Ford application.
Re: High-Tech Parking Cables Lokar (DANA / Explorer disc ) [Re: faud88] #1217999
04/17/12 10:01 PM
04/17/12 10:01 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
GM setup using the LOKAR kit
Re: High-Tech Parking Cables Lokar (DANA / Explorer disc ) [Re: faud88] #1218000
04/17/12 10:04 PM
04/17/12 10:04 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
GM CABLE and the Lokar cable -
Re: High-Tech Parking Cables Lokar (DANA / Explorer disc ) [Re: faud88] #1218001
04/17/12 10:10 PM
04/17/12 10:10 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
I will post some addtional photos of my stock setup shortly.
Re: High-Tech Parking Cables Lokar (DANA / Explorer disc ) [Re: faud88] #1218002
04/17/12 11:26 PM
04/17/12 11:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Where is your mismatch ? Do both caliper cables go all the way to the front of the car ?
Re: High-Tech Parking Cables Lokar (DANA / Explorer disc ) [Re: JohnRR] #1218003
04/17/12 11:52 PM
04/17/12 11:52 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
No, there is an equalizer that is under the body...Tim
Re: High-Tech Parking Cables Lokar (DANA / Explorer disc ) [Re: astjp2] #1218004
04/18/12 12:00 AM
04/18/12 12:00 AM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
Tim is correct. I have no problem until I get up to the actual foot brake.
Re: High-Tech Parking Cables Lokar (DANA / Explorer disc ) [Re: astjp2] #1218005
04/18/12 01:13 AM
04/18/12 01:13 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I knew that but he went from showing the caliper tothe E brake pedal under the dash and nothing in between.
Re: High-Tech Parking Cables Lokar (DANA / Explorer disc ) [Re: faud88] #1218006
04/18/12 01:15 AM
04/18/12 01:15 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what's the problem it goes thru the hole in the firewall ? you need a thick washer on the under floor side that fits the cable and is bigger than the hole in the floor ???
Or am I missing something ?
