No Tail Flashers 69 Charger
#1217993
04/17/12 08:47 PM
04/17/12 08:47 PM
Posts: 1,554 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
Have the Hazard-Flashers working on the Front and Hood. Turn Signals work in rear but no Flashers.
Turn Signal Switch?
Thoughts....
1969 Hemi Charger R/T, 1970 Charger 472 Hemi 6 Sp 1969 Charger Pro Tour Project 1971 Barracuda Convert 1970 440 6pack Superbird, 1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue) 1967 Barracuda Convert 1968 Barracuda Coupe 1972 Charger Rallye wanna be RT 1972 Sebring Plus 440-6 Clone 1969 Coronet Pro Street 2009 Challengeer SRT8 stick 1992-1986 Body 2500 4x4 440 stick 1982 Ramcharger 318 Sniper- getting enhanced. 1991.5 W250 Cummins- Big Chief
Re: No Tail Flashers 69 Charger
[Re: 440PURSUIT]
#1217994
04/17/12 08:51 PM
04/17/12 08:51 PM
RapidRobert
rearward from the TS sw the hazards/TS use the same circuit(s) so yes I'd check the TS sw. I'd seperate the connector & check continuities
[Re: mikemee1331]
#1217997
04/17/12 11:53 PM
04/17/12 11:53 PM
Posts: 1,688 Marlboro, NY, USA
Rick_Ehrenberg
Marlboro, NY, USA
chargers use the rocker style switch? make sure each post on the back carries voltage. each of the 4 pins is for a corner light. do the lights (turn signals) in the dash light up as they should (both blinking together)?
Actually, the 4-way (emerg flasher) circuit is standalone. The switch is bizarre, too. Off, there's no continuity between any of the pins. On, all 4 pins have continuity. One pin is fed pulsed +12v from the 4-way flasher, one goes to both 32 CP rear filaments, one each to FF and RF.
Rip it all out and all else still works normally.
On the car with the problem, as long as the brake lights work, and both front signals, the defect is almost certainly the TS switch.
Rick
