keisler vs gear vendors vs A&A TRANS vs TCI #1217473
04/17/12 12:52 PM
04/17/12 12:52 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
which of these is the best bargain and easiest install for an auto overdrive trans.?
it seems most of them require you to butcher up your car to get them in.
Re: tremec vs keisler vs gear vendors vs A&A TRANS vs TCI [Re: CUDA8U] #1217474
04/17/12 12:58 PM
04/17/12 12:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You left out Passon , if you truly want a bolt in with pretty much no other than expending the speedo cable then the Passon OD is the way to go , if the car is already a 4 speed you take one out and install the other , driveline angles are not changed .
If you want cheap sell it and buy a fox body mustang .
Re: tremec vs keisler vs gear vendors vs A&A TRANS vs TCI [Re: CUDA8U] #1217475
04/17/12 12:58 PM
04/17/12 12:58 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
What are you looking for?....what's the "goal" for your car?...nothings a "bargin" in the aftermarket, price shouldn't be the "influence" in your choices for a performance transmission
Re: tremec vs keisler vs gear vendors vs A&A TRANS vs TCI [Re: CUDA8U] #1217476
04/17/12 12:59 PM
04/17/12 12:59 PM
Texas
racer_amx Offline
racer_amx  Offline
Texas
I vote Keisler, their fairly straightforward so it wasnt too tough but i havent had experience with gear vendors, [Email]A@A[/Email] trans, or TCI, so i couldnt say if they are an easier install or not.
Re: tremec vs keisler vs gear vendors vs A&A TRANS vs TCI [Re: JohnRR] #1217477
04/17/12 12:59 PM
04/17/12 12:59 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
i'm not worried about the cost,i don't want to start cutting up the car and Ford is a bad word here!
Re: tremec vs keisler vs gear vendors vs A&A TRANS vs TCI [Re: CUDA8U] #1217478
04/17/12 01:06 PM
04/17/12 01:06 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
What's the concern about "cutting up" the car, if your going to modify the driveline, and you need to mod a floor, wether it be a few "bumps/dimples", to trimming off excess metal flanges,etc, or reshaping a hump slightly, what's the big deal?...the benefits of an OD, IMHO out weigh the "modification(s)" needed to install an OD transmission
Re: tremec vs keisler vs gear vendors vs A&A TRANS vs TCI [Re: CUDA8U] #1217479
04/17/12 01:06 PM
04/17/12 01:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is the car an automatic or a stick ? Do you want an auto or a stick ?
Re: tremec vs keisler vs gear vendors vs A&A TRANS vs TCI [Re: JohnRR] #1217480
04/17/12 01:08 PM
04/17/12 01:08 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
original post says auto overdrive
Re: tremec vs keisler vs gear vendors vs A&A TRANS vs TCI [Re: CUDA8U] #1217481
04/17/12 01:10 PM
04/17/12 01:10 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ok , but you threw tremec in there and as far as I know tremec is a stick .
You are stuck with gear vendors if no cutting is requirement , you'll have to shorten the driveshaft and check the pinion angle.
Re: tremec vs keisler vs gear vendors vs A&A TRANS vs TCI [Re: CUDA8U] #1217482
04/17/12 01:16 PM
04/17/12 01:16 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I'm rebuilding and putting in a borg warner T56 6-speed manual trans. It will require me to cut the trans hump and torsion bar crossmember. However, look at my car. Does it honestly look like the type that anyone would ever care what I did?
If you absolutely want NO body mods, then consider a chevy 700R4 trans or the keisler auto/od which is a gm 4l60-e, basically an electronic version of the 700R4. It's smaller than the mopar overdrives of the same era, closer size wise to a 727. You will still have to mod other things like trans cooler lines, driveshaft, kickdown, shifter, etc but nothing permanent.
Re: tremec vs keisler vs gear vendors vs A&A TRANS vs TCI [Re: DAYCLONA] #1217483
04/17/12 01:16 PM
04/17/12 01:16 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
True, but aren't the GM/Keisler units a better fit compared to a GV or 518?
EDIT - Daytonaturbo answered that...
Re: tremec vs keisler vs gear vendors vs A&A TRANS vs TCI [Re: JohnRR] #1217484
04/17/12 01:25 PM
04/17/12 01:25 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
I've just reading about several mods needed.....cutting in floor patches,denting floor in,cutting cross members and adding after market ones that need new holes drilled.I don't have a problem cutting the drive shaft since they seem to be easier to find but cutting holes in a perfectly good floor is beyond what I want to do let alone denting it with a ball pean.
I see in the Keisler ad on moparts they are advertising a perfect fit trans coming soon.
Re: tremec vs keisler vs gear vendors vs A&A TRANS vs TCI [Re: CUDA8U] #1217485
04/17/12 01:26 PM
04/17/12 01:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: tremec vs keisler vs gear vendors vs A&A TRANS vs TCI [Re: JohnRR] #1217486
04/17/12 01:29 PM
04/17/12 01:29 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The Keisler Auto4 does not require "cutting" either, I've done both the Gear Vendors and the Keisler in the 70-4 B/E application, the GV will reqire some massaging of the floor/tunnel with a hammer, esp if using one of the earlier (pre2008) units, both require a new driveshaft,...the OP car IIRC is a 70 Challenger 440, so if Keisler is your choice, I'd opt for the stage 3 Auto4....the GV will set you back $3k...the Keisler, depending on your choice of Stage level, and electronic options will set you back $4500-$5K, but your getting a complete transmission, driveshaft, shift control, Thottle valve cable, crossmember, transmission mount, reprogramming kit for your stock shifter, shift cable, speedometer cable, transmission lines, torque converter, flex plate,and assorted other componets for installation...and it is a "bolt-in" application...
The GV is a tailshaft adapter, the OD unit, an auto control module,...you disasemble/adapt and install to your existing transmission, the driveshaft is on you
Both are good units, the choice is what you want to spend, the Keisler is .70 OD finial ratio, the GV is .78 OD finial ratio,...but the Keisler has the ability from dash control to alter shift points, and shift firmness thru out the range, the GV is either on or off, or you can drive in "auto" mode, and the unit will shift on/off at preset speed ranges....
Mike
Re: tremec vs keisler vs gear vendors vs A&A TRANS vs TCI [Re: DAYCLONA] #1217487
04/17/12 01:34 PM
04/17/12 01:34 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
thanks, I'm definately leaning toward the Keisler.I'm going to call them and get a quote.
Re: tremec vs keisler vs gear vendors vs A&A TRANS vs TCI [Re: CUDA8U] #1217488
04/17/12 01:37 PM
04/17/12 01:37 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I'd recommend that you ask for Jeff ext 210
Keislers toll free line is 1 888 609 0094...also 1 865 609 8187
Mike
Re: keisler vs gear vendors vs A&A TRANS vs TCI [Re: CUDA8U] #1217489
04/17/12 03:04 PM
04/17/12 03:04 PM
Dandridge TN
Dabee Online content
Dabee  Online Content
Dandridge TN
I have a GV in my 69 Bee and love it. I added a manual reverse valve body to my 727 and drive it like a four speed. I didn’t need to cut anything on the car. All I did was put a coupe (two) 3/16 dimples in the trans tunnel to get it in there. You do have to shorten the drive shaft and shim the axel housing to get proper pinion angle. I also bypassed the GV control module and use a foot switch to engage/disengage the GV.
Re: tremec vs keisler vs gear vendors vs A&A TRANS vs TCI [Re: DAYCLONA] #1217490
04/17/12 11:47 PM
04/17/12 11:47 PM
Michigan, USA
ramman5600 Offline
ramman5600  Offline
Michigan, USA
Mike
Not sure how much of rush you are in, but I was contemplating this very question and thought I was going to go the keisler route, but wound up going with another company and their 4l60e "kit". It is not exactly the same as the keisler setup (uses an adapter setup instead of a "custom" bell housing), but they are the ones who actually build the converter and trans and use the best controller instead of out-sourced pieces {not saying that is an issue, just my preference to have the builder be the seller in this case). They don't provide a driveshaft, but I can get a custom shaft local - fairly reasonable. The shop is doing the work currently and hope to have everything up and running soon. I can let you know how it goes if interested. On a side note I have not dealt with any company that has had as good customer service as the one I went with. PM me if you are interested as I am not trying to upset any of the current advertisers.
-C
Re: tremec vs keisler vs gear vendors vs A&A TRANS vs TCI [Re: ramman5600] #1217491
04/18/12 12:13 PM
04/18/12 12:13 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Will a GV from a Volvo swap on to our trannies?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: tremec vs keisler vs gear vendors vs A&A TRANS vs TCI [Re: Rug_Trucker] #1217492
04/18/12 12:46 PM
04/18/12 12:46 PM
dogdays Offline
dogdays  Offline
Here is the wikipedia writeup on the overdrive unit that started out as the Laycock de Normanville overdrive and ended as the GearVendors. Funny how it has changed little in design since it was first used in British cars with tiny four and six cylinder engines. And Rug, if you have a machine shop you can adapt one of those from a Volvo onto anything that moves. You just have to want to bad enough, kind of like putting a big block chevy into a VW. It's not just a "swap".
From Wikipedia:
"The vast majority of overdrives in European cars were manufactured by an English company called Laycock de Normanville (later GKN Laycock), at its Little London Road site in Sheffield, which is now demolished and remanufactured in the UK by an ex-Laycock de Normanville employee trading as Overdrive Spares.[2] The system was devised by a Briton, named Captain Edgar J de Normanville (1884–1968),[3] through a chance meeting with a Laycock Products Engineer. De Normanville overdrives were found in vehicles manufactured by Ford, British Leyland, Jaguar, Rootes Group and Volvo to name a few. Another British company, the former aircraft builder Fairey, built a successful all-mechanical unit for the Land Rover, which is still in production in America today.
The first production vehicle to feature the Laycock system was the 1948 Standard Vanguard Saloon. The first unit to be created was the A-type overdrive, this was fitted to many sports cars during the 1950s. Several famous marques used A-type overdrives, including Jaguar, Aston Martin, Ferrari, Austin-Healey, Jensen, Bristol, AC and Armstrong Siddeley. Later the A-type overdrive was to be fitted to the entire range of TR cars.
In 1959, the Laycock Engineering Company introduced the D-type overdrive, which was fitted to a variety of motor cars including Volvo 120 and 1800s, Sunbeam Alpines and Rapiers, Triumph Spitfires, and also 1962-1967 MGBs (those with 3-synchro transmissions).
From 1967 the LH-type overdrive was introduced, and this featured in a variety of models, including 1968-1980 MGBs, the MGC, the Ford Zephyr, early Reliant Scimitars, TVRs, and Gilberns.
The J-type overdrive was introduced in the early 1970s, and was adapted to fit Volvo, Triumph, Vauxhall/Opel, American Motors and Chrysler motorcars, and Ford Transit vans.
The P-type overdrive marked the last updates and included both a Gear Vendors U.S. version and a Volvo version. The Volvo version kept the same package size as the J-type but with the updated 18 element freewheel and stronger splines through the planet carrier. The Gear Vendors U.S. version uses a larger 1.375 outer diameter output shaft for higher capacity and a longer rear case.
Over a period of 40 years, Laycock Engineering manufactured over three and a half million overdrive Units, and over one million of these were fitted to Volvo motorcars.
In 2008 the U.S. company Gear Vendors, Inc.[4] of El Cajon, California purchased all the overdrive assets of GKN to continue production of the U.S. version and all spares for J and P types worldwide.
The system features an oil pressure operated device attached to the back of the standard gearbox operating on the gearbox output shaft. Through a system of oil pressure, solenoids and pistons, the overdrive would drop the revs on whatever gears it was used on by 22%. For instance, the overdrive system applied to a Triumph TR5 operates on 2nd, 3rd and top gear. When engaged, the overdrive would drop the revs by approximately 450 RPM. The advantages this had on fuel consumption was quite marked over long distances."
End quote.
R.
