70 gtx steering column #1216990
04/16/12 05:26 PM
04/16/12 05:26 PM
70GTXer Offline OP
70GTXer  Offline OP
can you swap a manual steering column with a power steering column? if not what are the differences.
thanks
Re: 70 gtx steering column [Re: 70GTXer] #1216991
04/16/12 07:50 PM
04/16/12 07:50 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I've heard the length is different, but that's coming 3rd hand and off memory so here's a so that you can get a definative answer.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 70 gtx steering column [Re: DPelletier] #1216992
04/16/12 08:29 PM
04/16/12 08:29 PM
70GTXer Offline OP
70GTXer  Offline OP
Thanks for the info
Re: 70 gtx steering column [Re: DPelletier] #1216993
04/16/12 09:03 PM
04/16/12 09:03 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
I've heard the length is different, but that's coming 3rd hand and off memory so here's a so that you can get a definative answer.you sir are correct and win today's prize.
Re: 70 gtx steering column [Re: mikemee1331] #1216994
04/17/12 12:19 AM
04/17/12 12:19 AM
70GTXer Offline OP
70GTXer  Offline OP
ok Mike so then can I just install a diff gear and a pump
Re: 70 gtx steering column [Re: mikemee1331] #1216995
04/17/12 11:34 AM
04/17/12 11:34 AM
DPelletier Offline
DPelletier  Offline
What I win?!
Re: 70 gtx steering column [Re: DPelletier] #1216996
04/17/12 11:56 AM
04/17/12 11:56 AM
70GTXer Offline OP
70GTXer  Offline OP
who wins and who was correct? me or mike
Re: 70 gtx steering column [Re: 70GTXer] #1216997
04/17/12 12:00 PM
04/17/12 12:00 PM
DPelletier Offline
DPelletier  Offline
Neither; *I* win! ...Mike was just commenting to me that I was right about the steering column being a different length, PS to non PS.
As far as your issue goes (again going off memory) I believe you can swap the parts from one to the other to convert. Which way are you trying to go?
Re: 70 gtx steering column [Re: DPelletier] #1216998
04/17/12 12:03 PM
04/17/12 12:03 PM
DPelletier Offline
DPelletier  Offline
Though I certainly don't recommend Jims; take a look at the steering column/box adaptor here:
http://www.jimsautoparts.com/steering_parts.htm
Re: 70 gtx steering column [Re: DPelletier] #1216999
04/17/12 12:05 PM
04/17/12 12:05 PM
DPelletier Offline
DPelletier  Offline
Re: 70 gtx steering column [Re: DPelletier] #1217000
04/17/12 12:09 PM
04/17/12 12:09 PM
DPelletier Offline
DPelletier  Offline
Re: 70 gtx steering column [Re: DPelletier] #1217001
04/17/12 12:11 PM
04/17/12 12:11 PM
DPelletier Offline
DPelletier  Offline
http://forums.moparmusclemagazine.com/70...sion/index.html
...note the comment at the bottom by Randy Bolig.
Re: 70 gtx steering column [Re: DPelletier] #1217002
04/17/12 12:13 PM
04/17/12 12:13 PM
DPelletier Offline
DPelletier  Offline
Re: 70 gtx steering column [Re: DPelletier] #1217003
04/17/12 09:03 PM
04/17/12 09:03 PM
70GTXer Offline OP
70GTXer  Offline OP
Have a manual steer now but column needs total restro. Found a complete restro power steer column on the cheap and bought it.Was hoping it was easy swap but now finding that to not be true.
Re: 70 gtx steering column [Re: 70GTXer] #1217004
04/17/12 10:27 PM
04/17/12 10:27 PM
Western NY
19SuperBee70 Offline
Western NY
A manual column is longer. Also, on a 70, the outer steering shafts are different lengths. You can lengthen and/or shorten the column as needed. You'll have to redrill and reinstall some nylon pins to retain the columns ability to collapse. I just did this in my 70 B body. Do a search and you should find the post.
Re: 70 gtx steering column [Re: 70GTXer] #1217005
04/18/12 12:02 AM
04/18/12 12:02 AM
Manhattan, IL
SixPackRT Offline
SixPackRT  Offline
Manhattan, IL
If memory serves me correct....The only thing different is the actual shaft. This of coarse providing that the two columns you have are the same in being either console auto/4speed or column shift. The shaft can be stretched and shortened, but the lower part of the shaft is slightly different if your doing an accurate restoration. The shaft itself is actually two pieces and the upper (steering wheel) parts are the same. I actually had stripped splines on my original steering column shaft (manual) and used the upper shaft portion from a spare (power) column I had. worked perfect. Hope this isn't confusing...
Scott
70 Coronet RT 440+6
64 Dodge 330 - Future Hemi Clone
17 Challenger Hellcat - Green Go Driver
86 Buick T-Type Turbo V-6
Re: 70 gtx steering column [Re: SixPackRT] #1217006
04/18/12 01:06 PM
04/18/12 01:06 PM
70GTXer Offline OP
70GTXer  Offline OP
Scott,
Both columns are for console shift.I will take 2 and make 1.
Thanks for the help.
Scott
Re: 70 gtx steering column [Re: 70GTXer] #1217007
04/18/12 02:19 PM
04/18/12 02:19 PM
Manhattan, IL
SixPackRT Offline
SixPackRT  Offline
Manhattan, IL
Scott, You will have to disassemble them both a little to remove the shaft. If you have a Factory Service Manual it would help. If not PM me I will scan the pages and send it to you.
Scott
70 Coronet RT 440+6
Re: 70 gtx steering column [Re: SixPackRT] #1217008
04/18/12 07:53 PM
04/18/12 07:53 PM
70GTXer Offline OP
70GTXer  Offline OP
Scott,
I do not have a manual if you could please send to tahiti190@hotmail.com
Scott
Re: 70 gtx steering column [Re: 70GTXer] #1217009
04/18/12 11:47 PM
04/18/12 11:47 PM
Manhattan, IL
SixPackRT Offline
SixPackRT  Offline
Manhattan, IL
Try this page as it outlines what your looking for. Barry has tons of good info on his site
http://www.hamtramck-historical.com/ServiceHighlights/1970PassengerCarHighlights11.shtml
Scott
70 Coronet RT 440+6
