first time at drag strip.. What COULD my car run? #1216748
04/15/12 11:58 PM
04/15/12 11:58 PM
5th and plum
redmist Offline OP
redmist  Offline OP
5th and plum
I say COULD because I am sorta scared to do it. I don't want to pile this thing into the side rails!
My combo is all stock 1968 Charger body as delivered with full interior and all.
I have a sway bar on the front, and 285/40 R-17 NT555's on the back. I want to run the car is street trim.
Motor is:
440 .30 over
SRP pistons at zero deck
OOTB Eddy 84cc heads
Compression should be around 10.2:1
Comp XS282S Solid 110 LSA 244 intake/ 252 Exhaust
.520/.540 lift
Crane roller 1.5 rockers
2" headers to 3.5 collectors. 3" Exhaust (I know way large)
Pro Form 850cfm double pump
K1 rods ARP 2000 bolts
Studed top and bottom
Electric fans and radiator
Rear is a 3.55 Posi,
Copes Trans with PTC 11" Converter built for my car.
I have attended a bunch of drags, but have never set foot on the track. I have a helmet if needed, and an extinguisher.
Should I go around the water box and not do a burnout with my street tires?
Here's a hand graphed chart based off what my engine did on the Engine Dyno when first built.
And a pic of the car as I will be racing it.
Re: first time at drag strip.. What COULD my car run? [Re: redmist] #1216749
04/16/12 12:07 AM
04/16/12 12:07 AM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
Congrats man!
Most importantly have fun, I'm sort new to it as well and can say biggest thing is seat time. I'm guessing depending on conditions and all I bet low 12's high 11's depending after you get it to hook right!
Mike
1969 Dodge Dart Swinger
Re: first time at drag strip.. What COULD my car run? [Re: redmist] #1216750
04/16/12 12:14 AM
04/16/12 12:14 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Don't be scared. If you can drive it down the street, you can drive it down the drag strip. Car and engine will be fine, traction will most likely be troublesome and DO drive around the water box. Just clean the tires off before staging. If you are still nervous, ask to make your first few passes with out someone beside you, most tracks will be happy to do that for you.
My guess is it will run about 8.75 in 1/8 mile.
Good luck and HAVE FUN!
Brian Dunnigan
Re: first time at drag strip.. What COULD my car run? [Re: '72CudaRacer] #1216751
04/16/12 12:40 AM
04/16/12 12:40 AM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
The 3.55's are gonna hurt ya...I would say low 13's-high 12's
Re: first time at drag strip.. What COULD my car run? [Re: MIKES_DUSTER] #1216752
04/16/12 01:04 AM
04/16/12 01:04 AM
Nanaimo, B.C.
GwaiiEagle Offline
Mannix
GwaiiEagle  Offline
Mannix
Nanaimo, B.C.
Don't do a burnout with the street tires. Quick chirp if you want, but drive around the water.
My very similar combo ran a best of 7.43 in the 8th (so about 11.70) with 28" slicks on a 3.91 gear.
10.2 compression 448 stroker
Magnum 282 Solid with 1.6 rocker so .528 lift 236 at 50
1.75 header 11 inch TQ
Performer RPM
A smooth accel. foot, I think, will get you a 12.10 or better is my guess.
The old mild 383 would get 8.43 on street tires, so you got that beat.
Re: first time at drag strip.. What COULD my car run? [Re: redmist] #1216753
04/16/12 01:14 AM
04/16/12 01:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Being that you want to run with your front sway bar
thats gonna hurt you but I would think a 12.30 to 12.70
is about the ET with street tires... have fun
Re: first time at drag strip.. What COULD my car run? [Re: MR_P_BODY] #1216754
04/16/12 01:17 AM
04/16/12 01:17 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Being in Boise, Idaho is not going to help...what is the elevation there?
Tony
70 AARCuda Vitamin C
Re: first time at drag strip.. What COULD my car run? [Re: 70AARcuda] #1216755
04/16/12 01:37 AM
04/16/12 01:37 AM
Renton Washington
Triple Threat Offline
Renton Washington
My personal experience; Sea level to Boise you're gonna lose about 3-4 tenths.
Should run mid-high 12's
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: first time at drag strip.. What COULD my car run? [Re: Triple Threat] #1216756
04/16/12 01:41 AM
04/16/12 01:41 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
You could make a few passes with the car or truck that you drive every day to get some seat time before running the Charger.
Re: first time at drag strip.. What COULD my car run? [Re: Darryls-Demon] #1216757
04/16/12 01:49 AM
04/16/12 01:49 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My guess is mid to low 12's if the tune is on. Ron
Re: first time at drag strip.. What COULD my car run? [Re: 383man] #1216758
04/16/12 02:27 AM
04/16/12 02:27 AM
5th and plum
redmist Offline OP
redmist  Offline OP
5th and plum
Awesome!
Had not thought about just running my truck first to get a feel for it. Great idea!
Re: first time at drag strip.. What COULD my car run? [Re: Darryls-Demon] #1216759
04/16/12 06:07 AM
04/16/12 06:07 AM
Texas
racer_amx Offline
racer_amx  Offline
Texas
+1
Def a good method to get soem practice in first.
Re: first time at drag strip.. What COULD my car run? [Re: racer_amx] #1216760
04/16/12 09:46 PM
04/16/12 09:46 PM
Central NC
gch Offline
gch  Offline
Central NC
You will have to get used to rolling into the throttle.With practice you might be surprised.
That thing is screaming for some drag radials.After you get comfortable with it try some and share the difference it makes.
Re: first time at drag strip.. What COULD my car run? [Re: gch] #1216761
04/16/12 09:53 PM
04/16/12 09:53 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
I may be wrong but isn't the NT555 the drag radial from Nitto?
Re: first time at drag strip.. What COULD my car run? [Re: davenc] #1216762
04/16/12 10:06 PM
04/16/12 10:06 PM
Newfoundland
codfish Offline
codfish  Offline
Newfoundland
Exactly what i was thinking.
12.3
codfish
Re: first time at drag strip.. What COULD my car run? [Re: codfish] #1216763
04/17/12 12:44 AM
04/17/12 12:44 AM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
12.20 112 mph
Re: first time at drag strip.. What COULD my car run? [Re: redmist] #1216764
04/17/12 01:02 AM
04/17/12 01:02 AM
oregon
savoyracer Offline
savoyracer  Offline
oregon
We oughta geta pool going here!..... .......I say 12.80-12.90
Re: first time at drag strip.. What COULD my car run? [Re: savoyracer] #1216765
04/17/12 08:25 AM
04/17/12 08:25 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Drive it like you stole it. If you feel it getting squirrely get out of it. The gear is going to hurt more than anything. If it hooks you should be in the mid 12's.
P.S. Chargers are cool
Coming soon!!!!
