Re: 426 Hemi issue...timing?
[Re: Cab_Burge]
#1216487
04/21/12 05:30 PM
04/21/12 05:30 PM
Posts: 10,766 North Dakota
6PakBee
North Dakota
When you go to WOT, does the engine backfire through the intake?
[Re: DaytonaTurbo]
#1216488
04/21/12 06:53 PM
04/21/12 06:53 PM
DaytonaTurbo
Manitoba, Canada
What is your timing? Initial, total and what rpm is it in by? Even an auto-tuning efi system can't mask a poorly tuned distributor.
[Re: Slipknot440]
#1216491
04/21/12 10:40 PM
04/21/12 10:40 PM
Posts: 12,419 Taxes & Virus's R-US, NY
Dragula
i honestly can't remember my initial timing numbers. No backfiring just a lull, followed by what feels like an engine trying to accelerate (roughly) then a lot of speed. I hopeful get a break in the rain so I can play with it later this week before I start consider saving for some distributor work
Have you driven it and various rpms to let the ECU learn the fuel curve yet? With mine, it took about an hour of driving on country roads to hit most of the rpms...I have 4.56 gears so it was pretty easy to cruise at higher rpms...By the time I was done with that drive almost rpm I drove it at showed a correction factor of 5% or less.
[Re: Slipknot440]
#1216492
04/22/12 02:40 AM
04/22/12 02:40 AM
DaytonaTurbo
Manitoba, Canada
Then why are you fighting with fueling before getting timing worked out? Timing affects fueling. Fueling does not affect timing. The fact that you don't know what your timing curve is should be raising flags. At least it does to me.
