Re: FLUX CORE WELDING WIRE???
[Re: JBurch]
#121631
09/16/08 11:06 AM
09/16/08 11:06 AM
Posts: 1,443 Maryland
Dads426
Maryland
I found that the flux-core wire carries more heat to the metal than the MIG process. The wire diameter is larger to accomodate the flux inside the wire so it has to be rigid enough so it won't collapse. It is hard to get the heat low enough. So, more burn-throughs and lots of spatter. I prefer argon/CO2 mix with sheet metal; have used flux-core for heavier repairs like subframe connectors, rear back brace, etc.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
[Re: Dads426]
#121632
09/16/08 11:08 AM
09/16/08 11:08 AM
DaytonaTurbo
Manitoba, Canada
[Re: Dads426]
#121635
09/16/08 11:25 AM
09/16/08 11:25 AM
Posts: 75,088 A Banana Republic near you.
JohnRR
thats because its a thicker OD wire diameter and you have to turn up the current .
[Re: macmic87]
#121640
09/16/08 06:40 PM
09/16/08 06:40 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
I don't believe so. I can't change the polarity on my MIG and I can run FC or solid wire. However, that does open some line of thinking. Changing the polarity often can affect the way a weld runs and hence can sometimes result in more or less splatter, regardless if its flux core, solid wire or even stick arc welding
[Re: macmic87]
#121641
09/16/08 08:24 PM
09/16/08 08:24 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
doesn't going from flux core to regular wire require that you change the polarity of the machine?
On my Hobart(Miller) 140 you have to swap these leads depending on if you are using gas or using flux. This setup is for flux core.
[Re: 446acuda]
#121644
09/16/08 10:26 PM
09/16/08 10:26 PM
JohnRR
yes you have to change the polarity , easy to do as this picture shows . my lincoln is the same way
