FLUX CORE WELDING WIRE??? #121628
09/16/08 09:51 AM
09/16/08 09:51 AM
Just South of The Motor City
limechallenger Offline OP
I recently saw some flux core welding wire , and happen to be out of gas for my 110v. wire welder,and was wondering if this gasless wire works as good or better than argon! I just use it for minor sheet metal repairs ,no heavy frame type welding. Chime in let me know!!
70 T/A Challenger 78 Aspen R/T 87 Indy 500 Dakota
Re: FLUX CORE WELDING WIRE??? [Re: limechallenger] #121629
09/16/08 10:01 AM
09/16/08 10:01 AM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
If I could help it, I would not use it! It spatters something wicked, ventilated a perfictly good pair of pants and a shirt one day. better to keep an extra bottle of gas.
Re: FLUX CORE WELDING WIRE??? [Re: limechallenger] #121630
09/16/08 11:02 AM
09/16/08 11:02 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
that wire is best suited for exh repairs and for welding overhead , and yes it spatters and can leave some real ugly looking welds .
Re: FLUX CORE WELDING WIRE??? [Re: JBurch] #121631
09/16/08 11:06 AM
09/16/08 11:06 AM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
I found that the flux-core wire carries more heat to the metal than the MIG process. The wire diameter is larger to accomodate the flux inside the wire so it has to be rigid enough so it won't collapse. It is hard to get the heat low enough. So, more burn-throughs and lots of spatter. I prefer argon/CO2 mix with sheet metal; have used flux-core for heavier repairs like subframe connectors, rear back brace, etc.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: FLUX CORE WELDING WIRE??? [Re: Dads426] #121632
09/16/08 11:08 AM
09/16/08 11:08 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Re: FLUX CORE WELDING WIRE??? [Re: Dads426] #121633
09/16/08 11:11 AM
09/16/08 11:11 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
I am the flux core welding master and have hundreds of welds on my ride, ground down and painted to hide the uglyness of the reality of welding with flux core.
However you can get some nice looking welds if its an important spot by blocking off the splatter area.
Now I just use a my reg mig and tossed two spools of flux.
Avoid it if you can...but it does work
Re: FLUX CORE WELDING WIRE??? [Re: Dads426] #121634
09/16/08 11:16 AM
09/16/08 11:16 AM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
I used to weld professionally and we used flux core on the heavier work to get better penetration. These were heavy duty 480v 200+ amp machines and we were running .06 (1/16") wire. I'm talking HUGE welds on heavy plate We also ran a shield gas of straight C02 with the fluxcore. That was supposed to help keep a constant current at the weld for even better heat and penetration.
Re: FLUX CORE WELDING WIRE??? [Re: Dads426] #121635
09/16/08 11:25 AM
09/16/08 11:25 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
thats because its a thicker OD wire diameter and you have to turn up the current .
Re: FLUX CORE WELDING WIRE??? [Re: JohnRR] #121636
09/16/08 01:47 PM
09/16/08 01:47 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Flux core is terrible. I still have a spool in the garage that I wont touch. Spatters, is nasty looking and hard to get the welder adjusted properly. Argon/CO2 mix only for me.
Re: FLUX CORE WELDING WIRE??? [Re: Posest] #121637
09/16/08 01:51 PM
09/16/08 01:51 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Only time I use it is outside, where the wind is blowing away the shield gas. Otherwise, it's great for hanging parts to paint.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: FLUX CORE WELDING WIRE??? [Re: limechallenger] #121638
09/16/08 01:52 PM
09/16/08 01:52 PM
Fort Lauderdale
Dave440 Offline
Dave440  Offline
Fort Lauderdale
Agree with the concensus. Have never used flux core with my MIG after seeing a friend show me some flux core welds on exterior sheet metal welds he did on his car. Flux core got the job done...but they're pretty nasty looking welds. Not smooth like gas MIG welding.
Re: FLUX CORE WELDING WIRE??? [Re: Dave440] #121639
09/16/08 06:06 PM
09/16/08 06:06 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
doesn't going from flux core to regular wire require that you change the polarity of the machine?
Re: FLUX CORE WELDING WIRE??? [Re: macmic87] #121640
09/16/08 06:40 PM
09/16/08 06:40 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
I don't believe so. I can't change the polarity on my MIG and I can run FC or solid wire. However, that does open some line of thinking. Changing the polarity often can affect the way a weld runs and hence can sometimes result in more or less splatter, regardless if its flux core, solid wire or even stick arc welding
Re: FLUX CORE WELDING WIRE??? [Re: macmic87] #121641
09/16/08 08:24 PM
09/16/08 08:24 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
On my Hobart(Miller) 140 you have to swap these leads depending on if you are using gas or using flux. This setup is for flux core.
Re: FLUX CORE WELDING WIRE??? [Re: 446acuda] #121642
09/16/08 08:42 PM
09/16/08 08:42 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Ya learn sumpn' new every day!! I should look to see if my Hobart does that.... Only had it 10 years LOL Never burned flux core with it tho. Got the C25 bottle with the deal and always ran solid wire
Re: FLUX CORE WELDING WIRE??? [Re: Scott Carl] #121643
09/16/08 10:21 PM
09/16/08 10:21 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
my dad is a retired welding supplies salesman. when i got my portable mig it was supposed to be setup for gas, but couldn't get a bead to look good. talked to my dad and he told me that the machine was probably set up for flux core. changed the polarity and presto better welds.
Re: FLUX CORE WELDING WIRE??? [Re: 446acuda] #121644
09/16/08 10:26 PM
09/16/08 10:26 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes you have to change the polarity , easy to do as this picture shows . my lincoln is the same way
