Bad PB booster?
#1216344
04/15/12 04:27 PM
04/15/12 04:27 PM
Posts: 738 OK
David_Trimble
OK
I've got a issue with my power brakes and the FS manual doesn't cover this....
WHen the engine is at idle (~750rpm), if I apply the brakes the engine sputters and dies. '69 Charger with PB drums, although the booster is meant for a PB disk setup (Bendix- the car apparently had disks in the beginning and someone down the line swapped them out for 10" drums. This will be rectified someday....) Also, the PB booster had been professionally rebuilt- about 10 years ago :/
It's sounding like to me that I've got a leak somewhere in the booster but it only happens when I apply the brakes- otherwise the engine idles ok (not great though IMO).
Has anyone run into this issue before? Any ideas as to what could cause this?
Thanks as always! David
'69 Dodge Charger R/T
Re: Bad PB booster?
[Re: Challenger 1]
#1216346
04/15/12 05:56 PM
04/15/12 05:56 PM
Posts: 10,738 North Dakota
6PakBee
North Dakota
Sounds like an internal leak in the booster. I don't think it is the check valve because the check prevents flow from the engine to the booster. Did you do the classic booster test yet? With the engine off, maintain a light pressure on the brake pedal. Start the car maintaining a slight pressure on the pedal. If the booster is functioning the pedal will drop slightly.
Re: Bad PB booster?
[Re: David_Trimble]
#1216349
04/15/12 06:09 PM
04/15/12 06:09 PM
6PakBee
North Dakota
Still sounds like you have an internal leak. But at least you have brakes which is usually a good thing.
Re: Bad PB booster?
[Re: David_Trimble]
#1216352
04/15/12 06:45 PM
04/15/12 06:45 PM
Challenger 1
Cincinnati, Ohio
I just checked out Rock - they want me to mail off my booster for a rebuild rather than send me one outright. If I'm going to have to do that I'd rather send it to Booster Dewey....
Probaly where they send it anyway.
