Valve Lapping #1216337
04/15/12 04:19 PM
04/15/12 04:19 PM
ont,canada
mopartuner Offline OP
ont,canada
I have a set of SB E-heads that were done at a good mopar race shop and used for a short time and then sat idle for 5 years.I tested them with some fuel to see if they were sealing and they didn't leak,then I took them apart and cleaned the heads up and now there is a couple of ports that leak verry slightly.Should I get some lapping compound and lap them or will I do more harm than good?
410 pump gas solis flat tappet cam 10.95 so far
Re: Valve Lapping [Re: mopartuner] #1216338
04/15/12 07:25 PM
04/15/12 07:25 PM
Az
Crizila Offline
Crizila  Offline
Az
Lapem in.
Fastest 300
Re: Valve Lapping [Re: Crizila] #1216339
04/15/12 07:35 PM
04/15/12 07:35 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
it works for me.
Re: Valve Lapping [Re: bonefish] #1216340
04/15/12 10:49 PM
04/15/12 10:49 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Did you put the valves back in their same cylinders ???
Use a VERY fine compound. Most of the standard over-the-counter crap is like gravel !!
Re: Valve Lapping [Re: Stanton] #1216341
04/15/12 10:56 PM
04/15/12 10:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes you need fine compound... but it cant be worse
if its leaking now... but thats also how they determine
the back cut on the valve
Re: Valve Lapping [Re: Stanton] #1216342
04/15/12 11:02 PM
04/15/12 11:02 PM
ont,canada
ont,canada
Yes I put the back where they came from
