Pros and Cons of Undercoating #1216117
04/15/12 12:48 PM
04/15/12 12:48 PM
Arizona
69rrgrabber Offline OP
Arizona
Trying to decide on if I should reunder coat the 69 Charger I'm working on. Despite no option code for undercoating of thefender tag, the car seemed to be undercoated from the factory. Is this common to have a car undercoated and nothing on the fender tag?
Any, I'm in Southern Arizona and not too worried about road salt or excessive rain. I am puting a quality sound / heat liner under the carpet so I wonder if that will be enough to supress heat and road sound. Anyone out there not re undercoat and regrett it? Why?
Thanks,
Carl
"It takes a Mopar to catch a Mopar!" 1969 Charger R/T 440 1969 Road Runner 383 1970 Cuda 440
Re: Pros and Cons of Undercoating [Re: 69rrgrabber] #1216118
04/15/12 01:14 PM
04/15/12 01:14 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
The undercoating from day 2 could be the old dealership gimmick from when the car was bought new. Used to be the first question they asked you when you bought a new car.
$20.00 worth of material, $3.00/hr oil change guy = a couple of hundred dollars in the dealerships' pocket.
It's been modified to today's standards though: they call it the "protection package". Etched glass and a black spray bomb of crap in the wheel-wells, or some stupid thing like that. Think they're up to 6 or 700 bucks now.....
Good question about the sound deadening.....
Mo' Farts
Moderated by "tbagger".
Re: Pros and Cons of Undercoating [Re: Grizzly] #1216119
04/15/12 01:37 PM
04/15/12 01:37 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Factory undercoated cars also had an underhood pad, does yours have one?
Re: Pros and Cons of Undercoating [Re: ScottSmith_Harms] #1216120
04/15/12 06:13 PM
04/15/12 06:13 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I'm becoming a fan of urethane bed liner in the wheel wells and stopping there.
Re: Pros and Cons of Undercoating [Re: 6PakBee] #1216121
04/15/12 11:04 PM
04/15/12 11:04 PM
california
Mr D21 Offline
Mr D21  Offline
california
what is the code for undercoating? And would it be the same LA vs Hamtrack - 70 challenger btw,,,
Re: Pros and Cons of Undercoating [Re: Mr D21] #1216122
04/15/12 11:17 PM
04/15/12 11:17 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Did you see my first question?
Re: Pros and Cons of Undercoating [Re: ScottSmith_Harms] #1216123
04/16/12 12:33 AM
04/16/12 12:33 AM
Arizona
Arizona
No, I don't think it had the under hood pad. The car was totally repainted, color change, about 15 years ago. But they did a bad job and the car never got finished.
The code for factory undercoating with the hood pad is J25 I think. I don't have it on my fender pad. The undercoating sure looks like the factory stuff but I don't know for sure. After all this work scraping it off I really hate to re undercoat it again.
With the wheel wells, were they all done standard at the factory or was that part of the under coating and hood pad option? It seems to make sense that I at least replace the undercoating in the wheel wells to prevent chipping.
Re: Pros and Cons of Undercoating [Re: 69rrgrabber] #1216124
04/16/12 12:43 AM
04/16/12 12:43 AM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
And NOTHING looks worse than seeing body color in the wheelwells.....
MB
Re: Pros and Cons of Undercoating [Re: HPMike] #1216125
04/16/12 01:40 AM
04/16/12 01:40 AM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
one way to tell if it was factory or dealership applied, is if there is evidence of masking off of certain areas under the car. the factory masked off areas like the leaf spring perches and a few spots on the torsion bar cross mount. they did this because they undercoated before assembly of suspension. dealership undercoating would probably be on the leaf springs, torsion bars maybe rear axle as it was sloppily applied over everything.
IIRC, all mopars had undercoating in the wheel wells except some LA built cars? maybe someone can correct me on this.
as far as undercoating your car, if you already have the old stuff scraped off, Id leave it off. I spent a lot of time and money to try and get my factory undercoated car to look good underneath. It works ok as a sound detonator, but something like fat mat or equivalent will work much better. not to mention it looks a lot cleaner with no undercoating and also doesn't look like your trying to hide anything.. hope this helps
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: Pros and Cons of Undercoating [Re: mopars_1] #1216126
04/16/12 02:17 AM
04/16/12 02:17 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Doesn't undercoating protect the paint from rock chips/debris ?
Re: Pros and Cons of Undercoating [Re: 69rrgrabber] #1216127
04/16/12 08:59 AM
04/16/12 08:59 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Wheel wells were always done , both front and rear along with a small area above the pinion snubber and maybe the tail of the trans above the spinning u joint ...
I'll let Scott or someone with more knowledge there correct this one ... I stopped paying attention to what's right a long time ago because most restored cars are wrong .
Re: Pros and Cons of Undercoating [Re: 69rrgrabber] #1216128
04/16/12 01:51 PM
04/16/12 01:51 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I didn't think undercoating appeared on the fender tag
Re: Pros and Cons of Undercoating [Re: JohnRR] #1216129
04/16/12 01:58 PM
04/16/12 01:58 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
The bottom of the gas tank was coated as well, IIRC.
MB
Re: Pros and Cons of Undercoating [Re: Morty426] #1216130
04/16/12 02:07 PM
04/16/12 02:07 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
On non undercoate ordered cars the front wheel wells were often NOT undercoated (more correctly referred to as sound deadener) when from the Los Angeles assembly plant. In addition the rears were often dine very sparingly with only small amounts getting on the surrounding areas like the has tank etc.
Re: Pros and Cons of Undercoating [Re: 69rrgrabber] #1216131
04/16/12 02:13 PM
04/16/12 02:13 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
I would only do the wheelwells. No reason to go the full undercoating route on a collector car IMO and whenever I see a car for sale with the full undercoating, I wonder what they are trying to hide.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Pros and Cons of Undercoating [Re: DPelletier] #1216132
04/16/12 02:25 PM
04/16/12 02:25 PM
Chicagoland
cudastruction Offline
Chicagoland
I agree. As a buyer, if it isn't a survivor with factory undercoating, I see undercoating as a way to hide something.
Re: Pros and Cons of Undercoating [Re: ScottSmith_Harms] #1216133
04/16/12 03:25 PM
04/16/12 03:25 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I didn't know that Scott.
One thing I have been trying to determine is if the front on my 69 383 Dart (hamtramack) was not undercoated when built. I can't say for sure because front fenders have been replaced from a front end collision back around 1980, but it looks to have never been done when new ????
Can't remember seeing gas tank undersides done on non undercoated cars but heree in the northeast everything I have stripped has been undercoated usually.
Re: Pros and Cons of Undercoating [Re: JohnRR] #1216134
04/16/12 03:37 PM
04/16/12 03:37 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
The bottom of the tank on my Hemi Challenger is coated, and I am 100% sure that it is original. Also had a survivor '70 GTX in here that had the bottom of the tank coated as well.
MB
Re: Pros and Cons of Undercoating [Re: HPMike] #1216135
04/16/12 07:39 PM
04/16/12 07:39 PM
None
71rm23 Offline
71rm23  Offline
None
I was under the impression that it was applied from the dealer. I could be wrong, done that before. My car was built in St. Louis. The car has undercoating on it. All I can say is that I'm removing it now to paint. With the coating, it has saved my car from the cancerous rust. With that, now I'm debating whether or not to re-apply it after paint.
Re: Pros and Cons of Undercoating [Re: 71rm23] #1216136
04/16/12 07:58 PM
04/16/12 07:58 PM
DPelletier Offline
DPelletier  Offline
Some cars got full undercoating from the factory, some were done at the dealership and some weren't undercoated at all (except the wheelwells as mentioned previously).
Obviously the undercoating has helped preserve the car and so the answer as to what to do depends on you: what are your plans for the car?
In my case, my car will never see snow, never see a dirt road and rain will be avoided; it won't be going out of it's heated shop in the winter and will likely only get driven a few times a month seasonally....therefore there is no need whatsoever for full undercoating and I like being able to see everything under the car clearly. I also think that should I ever sell the car, buyers will also want to clearly see the condition of the underside of the unibody.
Now, if you are planning on using your car as a year round daily driver, I'd put the undercoating back on.
