505" RB stroker quench #1216040
04/15/12 09:20 AM
04/15/12 09:20 AM
Home of the Bluegrass
MoparJunkie Offline OP
Hey guys... My piston is .010 in the hole. What gasket is available that will give me no more than .030 compressed thickness? I want to stay in the .035-.040 range...
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: 505" RB stroker quench [Re: MoparJunkie] #1216041
04/15/12 09:34 AM
04/15/12 09:34 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Cometic has a .027.
Re: 505" RB stroker quench [Re: JohnRR] #1216042
04/15/12 02:13 PM
04/15/12 02:13 PM
I remember hearing about those who sells them?
Re: 505" RB stroker quench [Re: MoparJunkie] #1216043
04/15/12 02:24 PM
04/15/12 02:24 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
http://www.summitracing.com/parts/CGT-C5461-027/
$87.
Re: 505" RB stroker quench [Re: 451Mopar] #1216044
04/15/12 09:26 PM
04/15/12 09:26 PM
Okay... Another issue. How important is quench??? I can run .039" gasket compressed and be at 11.06. Use the gasket I have now which is .043 compressed and I'm 10.9. If I go to the cometic at .027 I'm in at 11.6. I don't know that I want to push the c/r that high. I would feel better at 11.06 with the felpro 1009 at .039. So that sets me a total of .049(gasket and piston .010" in the hole...)I know with "quench" you want to stay in the .035-.040, so should I even fret about "quench"???? Or is there going to be a huge difference by not sticking to the "quench" guidelines?
Re: 505" RB stroker quench [Re: MoparJunkie] #1216045
04/15/12 11:26 PM
04/15/12 11:26 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I like to shoot for the best quench I can get even if it means a tad higher comp. The best quench is of course in the .040 to .042 area. Are you running aluminum heads ? At .049 you will still have a little quench. My quench is about .046 and I have 10.6 comp with my aluminum Indy EZ heads and I have no spark knock or ping at all with 37 degrees total. If its aluminum heads I would try to keep it about 11.0 at the highest as it will also depend on the cam you use. Iron heads I like to keep at 10.0 and this is with quench on both heads. If you can get it in the .045 area and no more then 11.0 thats what I would shoot for but even at .049 you may get away with it depending on the cam for cyl pressure. Ron
Re: 505" RB stroker quench [Re: MoparJunkie] #1216046
04/16/12 02:35 AM
04/16/12 02:35 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
You want the tightest quench you can get without pistons hitting heads/valves, etc. You'll be less likely to have spark knock at 11.06:1 with proper quench than you'll have with 10.9:1 with less than proper quench. So to answer your question, quench is important.
Re: 505" RB stroker quench [Re: MoparJunkie] #1216047
04/16/12 02:12 PM
04/16/12 02:12 PM
dogdays Offline
dogdays  Offline
What head are you using?
R.
Re: 505" RB stroker quench [Re: dodgeboy11] #1216048
04/16/12 02:34 PM
04/16/12 02:34 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 505" RB stroker quench [Re: Rug_Trucker] #1216049
04/16/12 05:03 PM
04/16/12 05:03 PM
Eddy's they are cut to 74cc...
Re: 505" RB stroker quench [Re: MoparJunkie] #1216050
04/16/12 08:14 PM
04/16/12 08:14 PM
dogdays Offline
dogdays  Offline
What's your valve notch cc? What shape is your piston head?
Here's my calculation: 505 / 8 = 63.125,
63.125 / 61 x 1000 = 1035 cc swept volume per cylinder.
To get volume above the piston for compression ratio r, divide swept volume by (r-1) so to get 11:1 compression you'd divide 1035 by 10 = 103.5 cc above the piston.
You say cylinder head is 74cc. Assume a 5cc valve notch and 2.5 cc in the 0.010" space above the piston, plus a 12cc head gasket. You have 93.5cc.
You need another 10cc to get down to 11:1.
Completing the calculation:
If your piston is flat top with just the 5cc notch, your true compression ratio with the 0.040" 12cc head gasket is 12.07:1.
E85, anyone?
R.
Re: 505" RB stroker quench [Re: dogdays] #1216051
04/16/12 10:03 PM
04/16/12 10:03 PM
The piston has a 17cc dish... Thats where we get the 11.0/1
Re: 505" RB stroker quench [Re: MoparJunkie] #1216052
04/17/12 04:08 AM
04/17/12 04:08 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
My 505 uses the 440 source 7.1" rod kit with the 17cc dish pistons, but I had the block milled to zero deck with the pistons, used the standard Fel-Pro 8519-PT1 head gasket (it has a larger bore size for the stealth heads), and 84cc Stealth heads for a compression ratio of 10.33:1.
With 74cc heads, 0.010" in below deck and the 0.027 Cometic gasket, I get 11.34:1 compression.
With the 0.039" 1009 Fel-Pro gasket, 11.02:1 compression.
I think the slightly higher compression with good quench would be better than the slightly lower compression ratio and less quench.
If your cam is larger than 290 degrees duration (and not installed advanced), you should be OK on pump premium if you keep the intake air cool and engine temps do not get too high.
Re: 505" RB stroker quench [Re: 451Mopar] #1216053
04/17/12 09:04 AM
04/17/12 09:04 AM
All things considered I think I'm going to go with the felpro 1009's. My new cam is a racer brown custom grind 243@.050 duration and .510" lift. I talked to Jim @ RacerBrown and we decided this is the best cam for my new goals... Do any of you guys use the copper sealer on the 1009's? The last 440 I built I used them with no sealer, but I sold the car shortly after? I had an oil seepage problem with this current stroker so I want to make sure I fix this seepage problem while I'm at it...
Re: 505" RB stroker quench [Re: MoparJunkie] #1216054
04/17/12 09:27 AM
04/17/12 09:27 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No need to use a sealer spray on a composite gasket .
Re: 505" RB stroker quench [Re: MoparJunkie] #1216055
04/17/12 08:07 PM
04/17/12 08:07 PM
Delray beach, Florida
P
Performance Only Offline
P
there seems to be some unknowns in the equation as far as figuring out a true compression ratio.
assuming you have a 4.350 bore and 4.250 stroke, the swept volume is 505.2976 at .010 in the hole with a .039 gasket with 4.410 bore in the gasket (9.7600 cc's) with a net 17 cc dish and 74 cc chamber, your C/R would be 10.9891-1
with a .027 X 4.410 it would be 11.3287-1
the real determining factor in my mind would be the cam specs. where does the intake valve close abdc? that will have more effect on the cylinder pressure than any one other thing mentioned. c/r by itself means very little IMO. i've built plenty of 12.5-1 motors with 185 psi cranking compression and conversely i've built 10-1 combo's with 200 + psi cylinder pressure.
machine shop owner and engine builder
Re: 505" RB stroker quench [Re: MoparJunkie] #1216056
04/17/12 08:25 PM
04/17/12 08:25 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
All things considered I think I'm going to go with the felpro 1009's. My new cam is a racer brown custom grind [Email]243@.050[/Email] duration and .510" lift. I talked to Jim @ RacerBrown and we decided this is the best cam for my new goals... Do any of you guys use the copper sealer on the 1009's? The last 440 I built I used them with no sealer, but I sold the car shortly after? I had an oil seepage problem with this current stroker so I want to make sure I fix this seepage problem while I'm at it...
Good luck with those 1009's. My 440 at 4.350" had such a big chamfer at the top of the bore that the 1009 gasket overhung the bore by a bunch. My understanding is that this is a common problem at least with later 70's blocks.
Just a heads up to check.
Kevin
Re: 505" RB stroker quench [Re: Twostick] #1216057
04/17/12 09:35 PM
04/17/12 09:35 PM
Isn't the bore on those gaskets 4.410? Why would there be a clearance issue? My bore is 4.355... I used them on a previous build that the bore was 4.350 with no issues???? Makes me wonder what the issue is???? Anyone else chime in here?
Re: 505" RB stroker quench [Re: Twostick] #1216058
04/17/12 09:46 PM
04/17/12 09:46 PM
PA
noplanb Offline
noplanb  Offline
PA
Kevin
+1. I had the same problem with a 75 440 block, the chamfers are ridiculously large. Needed the 8519 (4.5" bore IIRC) as the standard Fel-Pros wouldn't cover the chamfer.
YMMV, but check it. Don't assume.
remember when you said honey, some day that car is gonna look so good in front of our house
Re: 505" RB stroker quench [Re: MoparJunkie] #1216059
04/17/12 09:48 PM
04/17/12 09:48 PM
dogdays Offline
dogdays  Offline
When the bore is enlarged it is common to chamfer the top, break the sharp corner. Going overboard with the chamfer tool (or if the factory went WAY overboard) can put the edge out under the gasket, creating a failure. We're only talking 1/32 of an inch. It's just something to look out for.
R.
