5.2/5.9 Magnum exhaust manifolds in early B-body #1215878
04/14/12 11:15 PM
04/14/12 11:15 PM
Pittsburgh,PA
RTSrunner Offline OP
Pittsburgh,PA
Has anyone ever used late magnum 5.2/5.9 exhaust manifolds in an early B-body?I'm wondering if any specific manifolds will fit-Ram truck,Van,Dakota,or Jeep.I have a '65 Coronet with a mild LA 318,the stock manifolds look a bit restrictive!Any header ideas that fit are welcome too.Thanks,RT
Re: 5.2/5.9 Magnum exhaust manifolds in early B-body [Re: RTSrunner] #1215879
04/15/12 12:26 AM
04/15/12 12:26 AM
Andrewh Offline
Andrewh  Offline
I don't know how well the bolt onto a 318, but I run a set from a 2000 durango in my 65 coronet, but I am running the 5.9 mag out of the same as well.
clears everything just fine.
But the early ones like 94 range are supposed to be bigger. I think mine are the 2.25 and the early are 2.5 instead. but don't remember for sure. I just remember a post that the early ones are bigger.
Re: 5.2/5.9 Magnum exhaust manifolds in early B-body [Re: Andrewh] #1215880
04/15/12 12:29 AM
04/15/12 12:29 AM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
92-93 only are larger.
Rick
Re: 5.2/5.9 Magnum exhaust manifolds in early B-body [Re: Andrewh] #1215881
04/15/12 01:06 AM
04/15/12 01:06 AM
Pittsburgh,PA
Pittsburgh,PA
Thanks guys,I know the magnums will bolt onto the 318 ok,fitting the chassis was my concern.Andrewh sounds like you have the answer,a '65 too!I will search some part numbers and interchange for fitment options.
RT
Re: 5.2/5.9 Magnum exhaust manifolds in early B-body [Re: RTSrunner] #1215882
04/15/12 02:04 AM
04/15/12 02:04 AM
Bowie, MD
Reggie Offline
Reggie  Offline
Bowie, MD
From June 1999 Mopar Muscle Pg 77 "Dakota Secrets":
1992 and early 1993 factory Magnum cast iron exhaust manifolds are larger than later manifolds. The 1992 manifolds are 2 1/8" inside diameter, and the newer models are 1 7/8" inside diameter. The casting numbers for the 1992 exhaust manifolds are:
53006617(driver's side)
53006618(passenger's side).
Re: 5.2/5.9 Magnum exhaust manifolds in early B-body [Re: Reggie] #1215883
04/15/12 08:30 AM
04/15/12 08:30 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
yes,, the 91/92 manifolds work fine.
I am truckless..
Re: 5.2/5.9 Magnum exhaust manifolds in early B-body [Re: Reggie] #1215884
04/15/12 01:22 PM
04/15/12 01:22 PM
Pittsburgh,PA
Pittsburgh,PA
Thanks for the photos Reggie.I think either will be fine for my 318.
RT
