Re: fuel line question? Pump to carb!
[Re: 1st_charger]
#1215789
04/14/12 10:02 PM
04/14/12 10:02 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
I used 5/16" brake line from the Napa. Got a 48" length. It had inverted flare tubing ends. Cut one end off, used the fitting with an adapter to attach to carb. Bent it with a handheld tubing bender tool to run forward over the intake runners, around the driver's side of distributor (big block), in front of distributor, and down to the pump (it has a vapor separator, but no matter). Fairly easy to bend, warmed it up a little to avoid kinks, looks factory, soory no pics as I'm out of town.
If you put a filter between pump and carb, might have to make some homebrewed or (if you can find them) factory-looking standoffs from the intake bolts or coil bracket bolt holes to add in the hose to tubing connections and keep the tubing in one place on top of the engine. I had to that when I later added the pressure regulator.
Also, wrapped the tubing in hose that I slit length-wise to aid in insulation from engine heat.
If I get some pics of it later this week, I'll post 'em.
[Re: MoparMarq]
#1215797
04/22/12 10:52 PM
04/22/12 10:52 PM
MoparMarq
Vancouver, WA
Last shot is top down view of previous shot. Used another section of 5/16 brakeline, custom bent to run from outlet of regulator to carb inlet. They only come in 12" and 20" lengths from my local Napa. 12" ws too short to accomodate the bends, and 20" was too long, so had to get the 20" length, cut it, put the fitting back on it, reflare it, and bend it to run to the carb.
Lots of work. And because the hardline has the hose on it for the full length to the regulator, it doesn;t look as factory or elegant as it might, but it's probably a little more functional.
HTH, Marq
