904 In my 88 Dakota???? #1215676
04/14/12 02:11 PM
04/14/12 02:11 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
I have a 904 in my 88 Dakota don't know what year the trans is. Do i need to check the fluid with it in park or neutral or does it make a difference. Thanks
Re: 904 In my 88 Dakota???? [Re: bobs69] #1215677
04/14/12 02:14 PM
04/14/12 02:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Engine running in neutral with trans up to operating temp and yes it makes a difference.
Re: 904 In my 88 Dakota???? [Re: JohnRR] #1215678
04/14/12 02:49 PM
04/14/12 02:49 PM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Hot fluid expands slightly and with a stock valve body its not charging the torque converter when in park. So the reading on the dipstick level will appear off.
