Correct 70 GTX console brackets #1215589
04/14/12 11:46 AM
04/14/12 11:46 AM
70GTXer Offline OP
70GTXer  Offline OP
Am trying to find the correct console (Center)shifter mount.Does the 70 have the rear support bracket attached
Re: Correct 70 GTX console brackets [Re: 70GTXer] #1215590
04/14/12 01:42 PM
04/14/12 01:42 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Here is pic from my 70 Sport Satellite . . . is that what you are looking for ???
Re: Correct 70 GTX console brackets [Re: a12rag] #1215591
04/14/12 07:15 PM
04/14/12 07:15 PM
70GTXer Offline OP
70GTXer  Offline OP
yes thats what i'm trying to find-where that carpet is laying at rear of shifter is there a horizonal bracket attached that the console bolts too?
P.S. Nice sport sat, are you restoring it
Re: Correct 70 GTX console brackets [Re: 70GTXer] #1215592
04/14/12 10:02 PM
04/14/12 10:02 PM
a12rag Offline
a12rag  Offline
The only brackets are the one a little away from the carpet (to rear of car)- welded to body. And then the other bracket that is welded to the rear side of the shifter . . . have a look at this pic . . . .
Thanks, yes, am in process of restoring the Sport Satellite. It is staying the way it came out of the LA plant, other than getting a 360 instead of 318. But it is FC7 (In Violet), factory A/C and Cruise Control, console auto buckets with 6 way drivers seat !
Hope this helps . . .
Cheers
Mark
Re: Correct 70 GTX console brackets [Re: a12rag] #1215593
04/15/12 05:31 PM
04/15/12 05:31 PM
70GTXer Offline OP
70GTXer  Offline OP
Mark,
Appreciate the pictures.They tell me the shifter bracket I got is incorrect as mine doesnt have the rear horizonal plate that the console attaches too.
Scott
Good luck on the restro, send pictures.
