Help identifying an old car #1215481
04/13/12 07:31 PM
04/13/12 07:31 PM
Salem
Grizzly Offline OP
Moparts Proctologist
Grizzly  Offline OP
Salem
Was going through some old pictures and came across this car. It's only an hour or so away from me (if it's still there). Anyone know what it is?
Mo' Farts
Moderated by "tbagger".
Re: Help identifying an old car [Re: Grizzly] #1215482
04/13/12 07:37 PM
04/13/12 07:37 PM
Friendly, WV
wedgeheaded Offline
wedgeheaded  Offline
Friendly, WV
39 Plymouth if I'm not mistaken.
Re: Help identifying an old car [Re: Grizzly] #1215483
04/13/12 07:42 PM
04/13/12 07:42 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
1939 Plymouth P8 Deluxe
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Help identifying an old car [Re: 68Cbarge] #1215484
04/13/12 09:20 PM
04/13/12 09:20 PM
Salem
Grizzly Offline OP
Grizzly  Offline OP
Salem
Thanks, guys!
Is it worth rescuing?
Mo' Farts
Re: Help identifying an old car [Re: Grizzly] #1215485
04/14/12 07:43 AM
04/14/12 07:43 AM
Friendly, WV
wedgeheaded Offline
wedgeheaded  Offline
Friendly, WV
If it still looks like that it is.
Re: Help identifying an old car [Re: wedgeheaded] #1215486
04/15/12 09:58 PM
04/15/12 09:58 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Expect it to need floor pans, and it looks like the driver side headlight is missing the lenses and trim, those parts are 39 only and sometimes difficult to find. Is the hood still there? is there correct paper work for it?
If it was priced right, I'd be getting it. Gene
Re: Help identifying an old car [Re: poorboy] #1215487
04/16/12 07:31 PM
04/16/12 07:31 PM
dogdays Offline
dogdays  Offline
DITTO. Worth fixing.
I love the "Willys look" front end.
R.
BTW, it's worth more as a street rod than restored.
Re: Help identifying an old car [Re: dogdays] #1215488
04/16/12 07:40 PM
04/16/12 07:40 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Worth grabbing if you can get it cheap.
I'd suggest jacking it up and pulling the front clip. It should have 2 big nuts under the radiator, then a few bolts at the back of the fenders to the cowl. Disconnect wiring and it will lift off then, allowing you to do tree work with more room and less fear.
Re: Help identifying an old car [Re: RodStRace] #1215489
04/17/12 02:56 AM
04/17/12 02:56 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
not to hijack this topic,,,ide grab the 39 also,, rod,,,do u know if the 1940 front end lifts off the same way ?? i am going to probably pull a motor on my 40 dodge,,i have not had time to look at all the attaching points yet,, but plan to move on it very soon,,, i know this info is providing nothing has been altered,,,,thanks
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: Help identifying an old car [Re: fstfish66] #1215490
04/17/12 11:44 AM
04/17/12 11:44 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
It should! They were all bolted together roughly the same.
I forgot that the bumper and brackets must be pulled too.
They come off pretty easy, the hard part is usually getting the bolts out of the fenderwell and at the front of the running board. They are typically rusted. Soak many times first!
Re: Help identifying an old car [Re: RodStRace] #1215491
04/17/12 04:57 PM
04/17/12 04:57 PM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
its been a southern car most of its life,,,has been apart many times by the previous owner for repaint,,,,so i should be good to go as far as rusty bolts,,providing n othing has been altered as far as the bolts and hard ware,,,
my real question i guess would be,,does the radiator shell stay with the frame or the front sheet metal ??
and the inner fender sheet metal,does it stay on the car or come off with the clip ? thank you
2015 cherokee
2013 R/T classic
Re: Help identifying an old car [Re: fstfish66] #1215492
04/17/12 05:37 PM
04/17/12 05:37 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Here's a shot of my 40.
Inner fenders, radiator and frame, all of it comes off in one chunk. Have a friend grab one side, you get the other. Trying it alone causes bends, DAMHIK!
Re: Help identifying an old car [Re: RodStRace] #1215493
04/22/12 03:50 AM
04/22/12 03:50 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
ok great thank you,,,ill post some info when i start taking the front end off,,,ill know more next week,,,,thanks again
2015 cherokee
2013 R/T classic
