Help identifying an old car
#1215481
04/13/12 07:31 PM
04/13/12 07:31 PM
Posts: 6,017 Salem
Grizzly
Moparts Proctologist
Salem
Was going through some old pictures and came across this car. It's only an hour or so away from me (if it's still there). Anyone know what it is?
Mo' Farts
Moderated by "tbagger".
Re: Help identifying an old car
[Re: 68Cbarge]
#1215484
04/13/12 09:20 PM
04/13/12 09:20 PM
Posts: 6,017 Salem
Grizzly
Salem
Thanks, guys!
Is it worth rescuing?
Mo' Farts
[Re: RodStRace]
#1215489
04/17/12 02:56 AM
04/17/12 02:56 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
Worth grabbing if you can get it cheap. I'd suggest jacking it up and pulling the front clip. It should have 2 big nuts under the radiator, then a few bolts at the back of the fenders to the cowl. Disconnect wiring and it will lift off then, allowing you to do tree work with more room and less fear.
not to hijack this topic,,,ide grab the 39 also,, rod,,,do u know if the 1940 front end lifts off the same way ?? i am going to probably pull a motor on my 40 dodge,,i have not had time to look at all the attaching points yet,, but plan to move on it very soon,,, i know this info is providing nothing has been altered,,,,thanks
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: RodStRace]
#1215491
04/17/12 04:57 PM
04/17/12 04:57 PM
fstfish66
levittown pa
its been a southern car most of its life,,,has been apart many times by the previous owner for repaint,,,,so i should be good to go as far as rusty bolts,,providing n othing has been altered as far as the bolts and hard ware,,,
my real question i guess would be,,does the radiator shell stay with the frame or the front sheet metal ??
and the inner fender sheet metal,does it stay on the car or come off with the clip ? thank you
[Re: RodStRace]
#1215493
04/22/12 03:50 AM
04/22/12 03:50 AM
fstfish66
levittown pa
ok great thank you,,,ill post some info when i start taking the front end off,,,ill know more next week,,,,thanks again
