09/15/08 10:12 PM
09/15/08 10:12 PM
South of Seattle
MBigDaddyM Offline OP
South of Seattle
From a motorhome, have potential buyer wants to know what the bolt pattern is crankshaft to flywheel, is it a 6 or an 8? Is there way to tell without removing the tranny? Also did they use 6 pack rods in the 413 truck motors? I hear a block with those heavy duty rods is worth more than a block with the standard rods. -BD
Will the last one leaving the US please turn out the lights.
Re: 72 413 [Re: MBigDaddyM] #121519
09/16/08 12:23 AM
09/16/08 12:23 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
My '72 MH 413, has a 6 bolt crank, I was told these are 8 bolt motors so who knows? you can't tell with getting the convert. out of the way.
I doubt it has 6BBL rods, but havn't swapped pans yet. I would bet a cheap lunch you'll find LY rods in the 413. A 440 might have them.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: 72 413 [Re: R70RUNNER] #121520
09/16/08 01:10 AM
09/16/08 01:10 AM
Los Angeles, CA
Mobarge Offline
Mobarge  Offline
Los Angeles, CA
Mine is a TH block, and has a six bolt crank. 440 rods too.
'71 SSP - SOLD!
Re: 72 413 [Re: Mobarge] #121521
09/16/08 01:23 AM
09/16/08 01:23 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: 72 413 [Re: 340SHORTY] #121522
09/16/08 02:13 AM
09/16/08 02:13 AM
dogdays Offline
dogdays  Offline
HAH! "six pack" rods are an answer to a question that shouldn't have been asked. Their heavy shanks add stress to the already-overstressed puny 3/8" rod bolts and add reciprocating mass to an engine whose pistons are lethal weapons, they are more than 2 lb each with pins.
It'll have a six-bolt crank, the 8-bolt was from the '50s. Basically it is a 440 crippled by 27 fewer cubic inches. Several board members have hauled 413s to the 'yard after unsuccessful attempts at selling them. You won't get rich from it.
R.
Re: 72 413 [Re: dogdays] #121523
09/16/08 02:41 AM
09/16/08 02:41 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Oh, Common Doggy! I have less then $100 into the '72 turd, it's in good shape for the short block, ended up with at set of known to be good 902's with bigger stainless valves for nothing! AND an offer for a blower... I just might end up with a 6-71 street motor for LESS then $3000 What the
Can't beat that, and the viual impact of a blower motor even 20% underdriven at 5-7psi
