1958 Dodge Truck #1215146
04/13/12 02:34 AM
04/13/12 02:34 AM
SK,Canada
gregsrt Offline OP
gregsrt  Offline OP
SK,Canada
This has been for sale for at least 4 months and I keep thinking it would make a nice kustom or hot rod shop truck(without the door lettering). Anybody have any photos of them lowered etc? Kind of tough to find pics. Anyone sell parts to lower the original susp or would it be better to swap frames with a newer one?
http://saskatchewan.kijiji.ca/c-cars-veh...QAdIdZ356404486
This is the only pic I've found of a modified one
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: 1958 Dodge Truck [Re: gregsrt] #1215147
04/13/12 02:36 AM
04/13/12 02:36 AM
SK,Canada
gregsrt Offline OP
gregsrt  Offline OP
SK,Canada
I'd do something like this. I know its a Ferd, but it looks cool.
Re: 1958 Dodge Truck [Re: gregsrt] #1215148
04/13/12 11:06 AM
04/13/12 11:06 AM
Thayer, MO
bohmer2 Offline
bohmer2  Offline
Thayer, MO
I do not believe anyone makes modified spindles for that era Dodge Truck. The Black truck likely has a Mustang II under it and the rear frame has been C'ed and bagged to get that drop to the ground look.
Lots of options to get that look the least expensive is probably going to MII front and C'ing the back and then piecing together an air bag kit from used parts.
Re: 1958 Dodge Truck [Re: gregsrt] #1215149
04/13/12 05:46 PM
04/13/12 05:46 PM
dogdays Offline
dogdays  Offline
With a solid front axle you'd contact Mor-Drop and use the stock front axle dropped maybe 3 inches.
Mor Drop
600 29th Avenue
Oakland, CA 94601
(510) 261-1888
I'd use at least 16s and suggest a 2000 12" Crown Vic brake disk over the stock hub, using the CV police calipers and brackets with custom mounts and hoses.
That's what I'm planning for my '64Dog.
Out back I'd find an 8 3/4 from '65 or newer and use one of Dr.Diff's disk kits on it. Or maybe the stocker would work?
Funny how with the right grille the truck looks almost modern! How about some late model Ram headlights?????
R.
Re: 1958 Dodge Truck [Re: dogdays] #1215150
04/14/12 10:11 AM
04/14/12 10:11 AM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
I'll throw in my 2 cents here. You could probably swap frames easier than the other options. Use a Dakota ( keep it Mopar) the track width is right, so it ain't too hard. I used the forward half of an 88 Dak on my 57. Gives it a pretty good ride, disk brakes, power rack and pinion and you can set the body at whatever hieght you want when you set the body on the frame.Just my opinion, let me know if you have any questions about this setup. Randy
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: 1958 Dodge Truck [Re: rattler] #1215151
04/15/12 02:12 AM
04/15/12 02:12 AM
SK,Canada
gregsrt Offline OP
gregsrt  Offline OP
SK,Canada
Thanks for the info guys. Still trying to decide if I should jump on it.
Re: 1958 Dodge Truck [Re: gregsrt] #1215152
04/15/12 10:11 PM
04/15/12 10:11 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The 318 in the pictures is a newer motor then what came in that truck, there may have been other upgrades done when the motor was installed. Originally it probably would have had the poly 318 with a 4 speed, or a flathead 6 that may have had a 3 speed. Very few V8 trucks would have came with a 3 speed.
That one looks pretty solid, but understand very few replacement parts are available for that era Dodge truck, what is there will likely be what you live with for original parts.
I had a 58 once, I was going to build it, but my brother in law talked me out of it. He put a 318 ,727 in it, got it painted, and sold it to someone else. I didn't know he was selling it until a month or more after it was gone. Gene
Re: 1958 Dodge Truck [Re: poorboy] #1215153
04/16/12 07:47 PM
04/16/12 07:47 PM
dogdays Offline
dogdays  Offline
It's a big back window truck. I say go for it.
Do all the body work first before you tear into the mechanicals. The late model 318 will get it around while you do the body.
It's not a restoration so you don't need much in the way of trim.
If you start on the drivetrain first, or God forbid, a frame swap, you will never finish it. Get the hard stuff done first. Then you will see whether you want to do the cheap route of a dropped axle and redone leaf springs or switching to a different front suspension.
While power steering and brakes are better, they can be done without for a while. I've been driving my '64Dog with stock drum brakes for decades and have put on about 60K miles, or 100K Km. That includes quite a few trips of 600 - 900 miles one way. The stock non-power steering was tightened up quite a bit with new kingpins, tie rod ends and adjusting the steering box. It would steer easier in parking lots if I didn't insist on running 10.50s in front. But it drives down the road just fine. Most of my trips are over the Continental Divide so I see a lot of mountain roads.
The payoff is I'm recycling an old truck (green, you know) and average one compliment a day from strangers. There is a video of it in Italy and pictures of it in France and Germany, as well as Sweden. Plus, good-looking women give me the thumbs-up on the interstate. So my ego gets a boost nearly every time I get into it.
R.
Re: 1958 Dodge Truck [Re: gregsrt] #1215154
04/16/12 11:02 PM
04/16/12 11:02 PM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
Jump Jump!!
Re: 1958 Dodge Truck [Re: gregsrt] #1215155
04/24/12 01:49 AM
04/24/12 01:49 AM
Bowling Green KY / Nashville, ...
300by500 Offline
300by500  Offline
A friend of mine made a cool "farm truck" by sitting his '52 IH on a mid 90s Dakota chassis. The trick is finding a frame that is the right width, as it's pretty easy to alter the length.
It is basically a re-bodied stock 318 automatic Dakota. He even kept the Dakota firewall and dash in it, which made it a relatively easy project. Ride height can be wherever you want it, it all depends on where you mount the body to the Dakota. Dead-reliable, comfortable, and no expensive parts. I've thought about doing the same with an old Dodge...
Re: 1958 Dodge Truck [Re: 300by500] #1215156
04/24/12 10:25 AM
04/24/12 10:25 AM
Thayer, MO
bohmer2 Offline
bohmer2  Offline
Thayer, MO
Not to highjack but can you get some photos of the firewall and dash. I am planning something similar with a 54 Panel Truck and a Durango...am curious to see what all he had to do with the firewall and dash.
