Power Glide install?? #1215117
04/13/12 01:17 AM
04/13/12 01:17 AM
WA
JD Dart Offline OP
JD Dart  Offline OP
WA
If you were putting one in your car. Would the TCI adaptor setup work or would you go with a case that fits the mopar? Any real time experience with them and advice would be appreciated.
Re: Power Glide install?? [Re: JD Dart] #1215118
04/13/12 02:24 AM
04/13/12 02:24 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I'd go with a mopar bell. It's SFI approved. Stock PG bell is not.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Power Glide install?? [Re: DemonDust] #1215119
04/13/12 02:28 AM
04/13/12 02:28 AM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
Jess I had a JW glide in my old Cuda. It has the 727 bell housing. It was super easy but I had to shim the starter.
Re: Power Glide install?? [Re: JD Dart] #1215120
04/13/12 02:33 AM
04/13/12 02:33 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
I've ran the TCI adaptor for years, and never had a problem with it, but the J&W Bell is what all the others we've done have had.
The bevel head Alen bolts on the adaptor plate and flywheel adaptor present an interesting challenge. You want to use thread locker on the threads to make sure they stay in place and don't lossen up. But you have to use anti-sieze on the heads or they will gall the aluminum, and weld themselves in place.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Power Glide install?? [Re: MoparBilly] #1215121
04/13/12 05:54 AM
04/13/12 05:54 AM
Chesterfield Twp. Mi.
John Burdine Offline
if i had the money, i would use a Reid case, bell, and tail.
Re: Power Glide install?? [Re: JD Dart] #1215122
04/13/12 11:42 AM
04/13/12 11:42 AM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
The TCI adapter will work but its junk, the plate is 1/4" and they then machine a 1/8" step for the shouldered transmission studs which look somewhat like splined lawnmower wheel studs, not anything particularly wrong with that, but it only leaves a 1/8th step in the plate which will eventually pull the studs completely through, won't happen right away, but it "will" happen, in my case in one season of racing. If the plate was 3/8th" it would probably be fine.
_____________
Just read Billy's post, sounds like maybe they use a tapered countersunk allen head now, instead of the shouldered stud like mine had, the unit I had was from the late 90's so hopefully they (TCI) re-engineered their holddown system.
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: Power Glide install?? [Re: John Burdine] #1215123
04/13/12 11:45 AM
04/13/12 11:45 AM
sg66mopar Offline
sg66mopar  Offline
Jess, I have both. I originally bought the TCI adapter kit back in the early 90s. When I did the big motor in 09 I started breaking the stock 'Glide bell housings.
I have the World aluminum block and if I remember you do too, right? It has the Glide bolt pattern on the back as well as the Mopar pattern.
So I put studs in the Chevy pattern on the block, removed the studs from the TCI adapter plate & drilled out the holes to about 1/2" so the block studs would poke through, then bought a JW Glide Ultra Bell that now bolts up to the motor.
Now the adapter plate is really just a motor plate. It's bolted to the Mopar pattern on the block with countersunk style bolts. I can remove the tranny without disturbing the motor.
The starter bolts up to an aluminum block that's attached to the motor plate.
Did all that make sense?
Re: Power Glide install?? [Re: sg66mopar] #1215124
04/13/12 12:02 PM
04/13/12 12:02 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
either that or the ATI is the way to go imho
Re: Power Glide install?? [Re: 23T Hemmee] #1215125
04/13/12 12:56 PM
04/13/12 12:56 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
TCI poor welding on wheel were starter ring came off and nearly cut thru my foot
home of the
Sox and Martin Hemi Duster
Re: Power Glide install?? [Re: HEMIFRED] #1215126
04/13/12 01:00 PM
04/13/12 01:00 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
2
home of the
Re: Power Glide install?? [Re: HEMIFRED] #1215127
04/13/12 01:03 PM
04/13/12 01:03 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
Now I use a different brand and 1/2" plate.
I combine the adapter as a mid mount so it also acts as a limiter
home of the
Re: Power Glide install?? [Re: HEMIFRED] #1215128
04/13/12 01:03 PM
04/13/12 01:03 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I have worked on both. The adapter is a hassle. Go with the bell. And get the aftermarket case.
2011 Drag Pak Challenger
Re: Power Glide install?? [Re: rickseeman] #1215129
04/13/12 01:54 PM
04/13/12 01:54 PM
Harrison Township, Michigan
Hemi SS Offline
Hemi SS  Offline
I am gathering pieces for a Hemi Dart build. I have the World block but it was from Mopar without the GM bolt pattern. I am looking at the JW Ultra bell for the glide. I have a few questions. If I use that bell , do I still need the crank adapter? And what flexplate should I get. The glide I am looking at has the turbo style input shaft.
Re: Power Glide install?? [Re: Hemi SS] #1215130
04/13/12 02:16 PM
04/13/12 02:16 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
I would recommend "The Wheel" from JW and their crank adapter.
Re: Power Glide install?? [Re: Blucuda413] #1215131
04/13/12 03:30 PM
04/13/12 03:30 PM
Las Vegas
afxcoronet Offline
afxcoronet  Offline
Las Vegas
Exactly, I'm running the Mopar to Glide Bell from JW along with JW's "the wheel" as well as their crank adapter...Eric at JW has been great to deal with. Everything went together perfect, and we are using 2 shims on the starter.
I have the TCI adapter as well as a JW Chevy Bellhousing hanging in the garage, not sure if I'll ever use it though, lol..
Curtis
Taking over the World one win light at a time.
Re: Power Glide install?? [Re: HEMIFRED] #1215132
04/13/12 04:34 PM
04/13/12 04:34 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Good welder could put that right back on..
Re: Power Glide install?? [Re: afxcoronet] #1215133
04/14/12 12:49 AM
04/14/12 12:49 AM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
JW bell, wheel & 2 starter shims here too, JW roller tail housing too, it all fits real nice, JW are excellent to deal with even for an overseas one off customer. dont always get that.
Re: Power Glide install?? [Re: SG duster] #1215134
04/14/12 01:24 AM
04/14/12 01:24 AM
you gotta get the new JW or CSR 1 piece cnc flexplate. no welded on ring gear crap. i little more money, but worth it.
Re: Power Glide install?? [Re: John Burdine] #1215135
04/14/12 06:50 AM
04/14/12 06:50 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I bought one from Reid 400.00
home of the
Re: Power Glide install?? [Re: HEMIFRED] #1215136
04/14/12 10:25 AM
04/14/12 10:25 AM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
The JW billet flexplate is recertifiable where "The Wheel" is no longer.
