Re: Msd and factory tach
[Re: 471b1dart]
#1215088
04/12/12 11:41 PM
04/12/12 11:41 PM
Posts: 5,445 So Cal
Sinitro
So Cal
Nope... Won't work.. I would suggest that you contact Julius @ Restorations by Julius 818.882.2825 He sells an electronic tach built by RedLine that goes rite into the 70 RR Ralley dash. And then you can connect directly to the MSD. Also its face has the correct color and fonts.. His website... www.rbyj.comhas more details.. Just my $0.02..
[Re: Sinitro]
#1215090
04/12/12 11:54 PM
04/12/12 11:54 PM
Posts: 516 ND
dodgedon
ND
I'm using an MSD 6AL with a 70's stock distributor with my 67 Chargers stock tach. Has worked great for the last 10 years. Not sure why yours would be different? I run the tack off the plug on the MSD box instead of the coil.
67 Charger 383 auto 75 Dodge CNT 800 CAT Diesel 2012 Ram Crew cab 5.7 4x4
[Re: dodgedon]
#1215091
04/12/12 11:56 PM
04/12/12 11:56 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
msd makes tach adapters for older or oem tachs
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: dodgedon]
#1215095
04/13/12 10:25 PM
04/13/12 10:25 PM
Posts: 5,445 So Cal
Sinitro
So Cal
Hmmm. In my 70RR, I tried running my MSD 6 with the Mopar electronic distributor and the OE tic/tach worked but was way off by about 40%. I swapped out the OE tach for one from Julius worked fine and is dead nuts on for calibration...
Just my $0.02..
