Dodge truck 20" wheels: '05 vs '10 #1215036
04/12/12 10:00 PM
04/12/12 10:00 PM
Alliance, Ohio
V
Valiant_Showoff Offline OP
V
Alliance, Ohio
Help. I bought a set of 20" rims off of a 2010 4x4 Dodge Quad Cab Ram to put on my 2005 4x4 Regular Cab Dodge Ram and they won't fit. The centering hub on the truck is just a hair too big for the wheels to seat. I don't have a micrometer to measure them, but I'm guessing it's about .020 or .030 too big. Not much, but enough that I can't get the aluminum 20's to go on the truck. Before I bought the used wheels, I made sure the bolt pattern was the same, but I never guessed the hub would be different.
Is the hub different between the truck years?
Does anyone know the correct hub diameter for each of those year's trucks? Best I can find by searching on-line is either 77.80 mm or 78.03 mm, but no one seems to know for sure.
I'm open for any suggestions because right now I'm rather pissed that I have a set of really nice 20" wheels that I can't put on my truck!
The pic is of the new wheels. My '05 had the ugly steel 17's.
THANKS
Re: Dodge truck 20" wheels: '05 vs '10 [Re: Valiant_Showoff] #1215037
04/13/12 06:35 PM
04/13/12 06:35 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Shouldn't be too hard to ream them out a little bit??? Brake wheel cylinder hone? AFAIK, the bolt pattern (or hub) did change in recent years. Sorry I don't have more specific info
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Dodge truck 20" wheels: '05 vs '10 [Re: GO_Fish] #1215038
04/14/12 12:53 AM
04/14/12 12:53 AM
Alliance, Ohio
V
V
Alliance, Ohio
Fixed. A little grinding did the trick.
