Re: Hellwig 1.375 front bar
[Re: AndyF]
#1214926
04/12/12 06:59 PM
04/12/12 06:59 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Is that for the old Dodge? You gonna get that thing out and makes some tracks Andy?
Mopar to the bone!!!
[Re: AndyF]
#1214928
04/12/12 07:52 PM
04/12/12 07:52 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
How does the rate compare to the smaller solid bar?
When are they going to crank out some Imperial stuff?
[Re: Jjs72D]
#1214934
04/13/12 03:09 AM
04/13/12 03:09 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
Will this be made for the 73-76 A bodies and 70-74 E body cars?
Hellwig has them for 73-76 A-bodies. I helped them test fit the prototypes. Took 3 iterations to get a really nice fit.
I'm almost sure they have them for E-bodies too.
73-76 A-body. You can not just copy a factory sway bar because of the added diameter puts the dip too close to the inside of the K-member. Also, you need all the room you can get because most 30+ year old K-members are dented which gives you even less space from stock.
Stout sway bar mount cross brace. Stout swaybar bushing clamps. Larger than stock end link bushing bolts...
[Re: autoxcuda]
#1214935
04/13/12 03:22 AM
04/13/12 03:22 AM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
73-76 A-body. You can just copy a factory sway bar because of the added diameter puts the dip too close to the inside of the K-member.
What's the difference between 73-76 A-bodies and older A-bodies when it comes down to suspension and K-frame and such?
[Re: autoxcuda]
#1214937
04/13/12 10:11 AM
04/13/12 10:11 AM
72Swinger
Nebraska
I've got a new Hellwig E-body rear bar in the box if someone wants a pic of it.
[Re: Jjs72D]
#1214938
04/13/12 01:34 PM
04/13/12 01:34 PM
Posts: 31,050 Oregon
AndyF
Not sure I fully understand your question. Hellwig makes tubular bars for almost all Mopar RWD vehicles. They do not make the 1.375 bar for everything though. The 1.375 bar is probably too big to fit inside the K-frame on the later model cars. Besides, with the shorter lever arms most people don't need that big of a bar.
Take a look at their website and see if you can find what you're looking for.
[Re: feets]
#1214941
04/26/12 11:14 AM
04/26/12 11:14 AM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
Kevin - a hollow bar is almost as stiff in torsion as a solid bar. The stress is linearly proportional to the distance from the center (at the center it is zero). The spring rate is proportional to the radius to the 4th power. It depends on the wall thickness of the tube. If you know the wall thickness I can do the math, but, just guessing I would say roughly twice as stiff due to the difference in outside diameter.
I am very aware of this. I did not know the wall thickness and that was the reason for the question.
When discussing with Dave at Hellwig, the difference in wheel rate between a 1 1/4 solid bar and 1 1/4 .250 wall was 390 lb/in vs 370 lb/in (73-76 a body). My math puts the 1 1/4 .188 wall at ~350 lb/in, 1 3/8 solid at 571-583 lb, and 1 3/8 .250 wall at ~542 lb/in wheel rate. All for a 73-76 A body. I'm sure you have them, but if you need the formulas for wheel rates from sway bars using the dimensions of the bar, let me know.
Wade
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
