changing the 3rd member cost? #1214762
04/12/12 11:53 AM
04/12/12 11:53 AM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
what's the typical cost to change out the third member on a 742 case?
these 4:11's are just too low and i'm not ready to dump $3000 into an OD tranny yet.I'm thinking a 3:55 yukon 3rd member as recommended by a mopar race guy would work
Re: changing the 3rd member cost? [Re: CUDA8U] #1214763
04/12/12 01:38 PM
04/12/12 01:38 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
call Dr Diff here on the board. He IS the rearend wizzard. He will set you straight and you wont find a better person to give advise..
I am truckless..
Re: changing the 3rd member cost? [Re: 340SHORTY] #1214764
04/12/12 06:28 PM
04/12/12 06:28 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Taken out of context, this statement takes on a whole new meaning.
Scott
1969 Super Bee, 383/4 speed
Re: changing the 3rd member cost? [Re: StukaJU87] #1214765
04/12/12 08:11 PM
04/12/12 08:11 PM
Kirkland, Washington
Pacnorthcuda Offline
keep your pinion to yourself!
Re: changing the 3rd member cost? [Re: CUDA8U] #1214766
04/12/12 09:53 PM
04/12/12 09:53 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I think with all new parts, around $1350.
Used ones with suregrip seem to go for $500+ easily.
Changing gears is the cost of gears (250 to be safe) + install kit (figure $40 min) + about $250 to set them up and assemble/rebuild, + bearing $ if needed. If you know someone with a press who is knowledgeable, you can save the $$ on the labor and you'd just be out the $$ for gears and bearings and install kit.
Re: changing the 3rd member cost? [Re: Exit1965] #1214767
04/12/12 10:02 PM
04/12/12 10:02 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
thanks,i have a complete set 3:23 and this 4:11 set that's nearly new i could sell to cover the cost,also that cost estimate is getting close to 50% of the cost of an over drive tranny
Re: changing the 3rd member cost? [Re: CUDA8U] #1214768
04/12/12 10:21 PM
04/12/12 10:21 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
you just want to change the ring and pinion from the 4.10 to 3.55???
I usually pay 2 hrs of shop time plus any parts..pinion seal...
about 175.00 dollars...
Is that your question?
Tony
70 AARCuda Vitamin C
Re: changing the 3rd member cost? [Re: 70AARcuda] #1214769
04/13/12 01:31 AM
04/13/12 01:31 AM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
Well i'm not sure what direction i want to go ,i like the bottom end power but would like a overdrive for the highway or higher gears
