Question's about a Vapor Seperator #121443
09/15/08 07:09 PM
09/15/08 07:09 PM
Cottage Grove, MN
K
kurtsdodge Offline OP
K
Cottage Grove, MN
I am in the process of making a clone 1969 Dodge Coronet R/T. The Car came with a 318 cubic inch motor. I have put in a 440 cubic inch motor. My questions are. Does the fuel seperator take the place of the fuel filter? Also what do I use for the return line to the gas tank from the fuel seperator. Also does the gas tank from a small block have the correct inlet to accept the return line. Any pictures or diagrams would be greatly appreciated( or links to web sites).
Thanks, Kurt
Re: Question's about a Vapor Seperator [Re: kurtsdodge] #121444
09/15/08 07:13 PM
09/15/08 07:13 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
yes, it is the filter on a RB motor
there is a 1/4" return line plumbed into the fuel system that is connected to a return fitting on the sending unit that is NOT on a 318 cars sender
Re: Question's about a Vapor Seperator [Re: gtx6970] #121445
09/15/08 07:21 PM
09/15/08 07:21 PM
Cottage Grove, MN
K
K
Cottage Grove, MN
Thanks, You answered all my questions except for two . Is the return line available aftermarket? Also what sending unit do I need to look for.
Re: Question's about a Vapor Seperator [Re: kurtsdodge] #121446
09/15/08 07:25 PM
09/15/08 07:25 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
return line is avail thru most any sources that carry fuel line products , such as Fine Lines, Inline Tube, Classic Tube products.
I personnally prefer Finelines
The sending unit is also avail thru various sources, it will have a 3/8" supply line fitting and a 1/4" return line fitting.
I'll forwarn you there are at least 4 companies making sending units and the cheap ones are just that, cheap.
