Page 4 of 4 1 2 3 4
Re: 512 Low Deck Dyno Results [Re: 440Jim] #1214400
07/10/12 04:54 PM
07/10/12 04:54 PM
detroit area
moderncylinder Offline
detroit area
my car weighing 3225 making 870hp at 8400-8600 going 1.20 in so ft at 2000-2500 ft da would run 8.80 at 150mph
a 64-65 ss/ba hemi car making 800 hp weighing 3450ish would run 9.35 going 1.25 in 60ft
to run 9.75 at 3450lbs id think it takes less than 750hp,, am i wrong?
Re: 512 Low Deck Dyno Results [Re: moderncylinder] #1214401
07/10/12 05:11 PM
07/10/12 05:11 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
A lot depends on which calculator you use 715 to 796 is the range of answers you can get from them. Still an hour before I get home and can see what day the run was made on.
2003 Dodge 3500 Diesel
1964 Plymouth Savoy White 2dr sdn. 512 stroked, Dominator, New Best 9.75 @ 138.50mph
2019 Challenger Scat Pack 1320 White Knuckle-K&N Cold air filter, Billit Oil catch can, drag radials stock 11.911 @ 114mph
Re: 512 Low Deck Dyno Results [Re: moderncylinder] #1214402
07/10/12 06:04 PM
07/10/12 06:04 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
3450 lbs with driver
1.39 60ft
4.01
6.21 @ 111.11 8th mile
8.13 1000ft
9.75 @ 138.50
I have been quicker and faster than him at about the same weight (depending on fuel I guess for that day) with a crappy 1.44 60ft. I have 60 more cubes and he has over a point more compression. I certainly feel I have more left to go in my setup as im sure he does!
not bashing or trying to get things riled up but I am hoping to get 800 on the dyno soon then prolly sell the engine fresh and start over (I get bored easy though)
Mopar Performance
Re: 512 Low Deck Dyno Results [Re: moparniac] #1214403
07/10/12 06:31 PM
07/10/12 06:31 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Density Altitude: 1855 feet above sea level
Stock and Mildly Modified Naturally Aspirated Engines 9.551 @ 141.557 MPH
Extensively Modified Naturally Aspirated Engines 9.634 @ 140.44 MPH
Time Temperature Humidity Pressure
8:53 AM 78.1 F 45 % 29.98 in
Re: 512 Low Deck Dyno Results [Re: Savoy1964] #1214404
07/10/12 07:09 PM
07/10/12 07:09 PM
NJ
arc Offline
arc  Offline
NJ
I come up with 725hp from the et 690 from mph this is y we shouldn't get crazy over dyno numbers.
Re: 512 Low Deck Dyno Results [Re: arc] #1214405
07/10/12 07:38 PM
07/10/12 07:38 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
everyone uses a calc one way or another...who knows which one is to say which is correct over the other just like dynos... it's all about the ET to me anyways....
Mopar Performance
Re: 512 Low Deck Dyno Results [Re: moparniac] #1214406
07/10/12 09:26 PM
07/10/12 09:26 PM
PA
moparacer Offline
moparacer  Offline
PA
I am currently running my car at 3200lbs and at 3000ft DA this past weekend in horrible air it went 9.45 @ 141
Never dynoed it but its right around 750 hp best I can figure.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: 512 Low Deck Dyno Results [Re: Savoy1964] #1214407
07/10/12 11:20 PM
07/10/12 11:20 PM
NC
440Jim Offline
440Jim  Offline
NC
Your car is running good. And should do a little better if you lean it out. The lack of sixty foot performance is holding it back. I don't know if it is converter, 1st gear ratio, or what.
Like I said, IMO your engine is making about the same as mine, and I am happy.
Re: 512 Low Deck Dyno Results [Re: 440Jim] #1214408
07/11/12 09:17 AM
07/11/12 09:17 AM
gregsdart Offline
gregsdart  Offline
That is solid performance out of a stock block build. The big body isn't helping you, and it will be interesting to see just how much you pick up as time goes by. The other part of the equation is always chassis driveline efficiency. Just how close to perfect your trans/converter/tire/suspension combo are also affects how good the motor looks hp wise. So I only see it going faster over time
Re: 512 Low Deck Dyno Results [Re: gregsdart] #1214409
07/11/12 09:24 AM
07/11/12 09:24 AM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Thanks for the comments I am happy with the performance. Running on SS springs (02-03) is most likely a limiting factor in 60ft and I don't want to go any bigger on tires 29.5 10.5W, bigger means tubbing.
Its an early 60's pushbutton trans and I am not sure what the first gear is.
Re: 512 Low Deck Dyno Results [Re: Savoy1964] #1214410
07/11/12 09:29 AM
07/11/12 09:29 AM
gregsdart Offline
gregsdart  Offline
Pretty sure it is 2.45 low. Never heard of a different ratio for a BB 727. Good luck with the suspension, I am betting you can make it work better. The tires ought to be sufficient based of 440JIMS, performance.
Re: 512 Low Deck Dyno Results [Re: gregsdart] #1214411
07/11/12 09:35 AM
07/11/12 09:35 AM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
Just did a little research and 2.45 is the first gear. I just need to do a little more testing I will be at Milan this weekend have to play with jetting and see what I get.
Re: 512 Low Deck Dyno Results [Re: Savoy1964] #1214412
07/11/12 10:02 AM
07/11/12 10:02 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Just throwing this out there,you may want to check into how much convertor slip you have on the top end I did not see anything posted about your rpm crossing the line or any information about your convertor.
Another thing that might affect your performance is the difference between your ignition and fuel system,and the systems used on the dyno.
Keith
Re: 512 Low Deck Dyno Results [Re: Dunnuck Racing] #1214413
07/11/12 11:09 PM
07/11/12 11:09 PM
Casco, MI
Savoy1964 Offline
Savoy1964  Offline
Casco, MI
I have found it hard to tell the exact rpm through the traps but the shift light will usually com on just as I go through the finish so approximately 7200-7300
Page 4 of 4 1 2 3 4
