Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: JohnRR] #1214307
04/15/12 12:20 AM
04/15/12 12:20 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
you guys need to quit showing him non-A body setups
nevermind incorrectly operating cobble jobs ...
He ain't gonna get it right if y'all are showing him the wrong setup.
Don't be the exception.
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: hooziewhatsit] #1214308
04/18/12 12:43 AM
04/18/12 12:43 AM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
Yep, you'll want to get the correct edelbrock adapter.
And, the slot in the kickdown MUST be held against the throttle studs at all times (by that long spring). If you have a gap there right now, that's your problem.
When you push the throttle open, the lever must move immediately with it. The long slot is so if the kickdown linkage binds up, the throttle can still close (before things get exciting ).
When I did my 4bbl conversion I had to extend the linkage about an inch so I had enough adjustment to keep it against the throttle stud.
yep, mine douse have a pinkey gap!
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: JohnRR] #1214309
04/18/12 12:58 AM
04/18/12 12:58 AM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
Ok, I know what I haft to do to get the rod right, now I just got to finger out wear to put the throttle cable at when I get the adapter bracket on!
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: Hoop] #1214310
04/18/12 01:08 AM
04/18/12 01:08 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
On the stock stud that you install on the adaptor bracket that you need to connect the trans linkage ... this isn't rocket science .
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: JohnRR] #1214311
04/18/12 01:29 AM
04/18/12 01:29 AM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
ok, if thats wear the throttle cable post to go, then I may not have a stock stud, I may haft to get a smaller stud for it, because it well not fit on thear!
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: Hoop] #1214312
04/18/12 07:43 AM
04/18/12 07:43 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: Challenger 1] #1214313
04/22/12 11:07 AM
04/22/12 11:07 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
x2 ....
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: bboogieart] #1214314
04/28/12 12:51 AM
04/28/12 12:51 AM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
This makes it sooo much easier
Hmmm
That looks like a G.M. throttle valve cable to me.
My 4 bbl. is a Holley but I just added a curved slotted bar from a /6 and it works great.
it could be gm, I don't think the throttle cable is the stock one, it seems too long to me!
I did get time to change it around today, but it, drives smooth, but steel likes some getting full throttle & I am goin haft to adjust some more on the kickdown to get the passing gear to work!
Also the throttle cable would not go on the stud because it had a nut in it that I had to take out to put it on the stud!
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: Hoop] #1214315
04/28/12 12:52 AM
04/28/12 12:52 AM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: Hoop] #1214316
04/28/12 12:56 AM
04/28/12 12:56 AM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
close up of throttle cable end befour I got the rest hooked up, just incase it helps!
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: Hoop] #1214317
04/28/12 01:04 AM
04/28/12 01:04 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
that is how it is supposed to be connected .
Look at the top bellcrank and you will see a hole in the bracket bolted to the engine and a hole in the part the linkage connects to , that is for a pin , use a drill bit , think the size is 3/16 , then adjust the rod to the carb so it is against that stud , and adjust the down rod from that linkage you pin so the trans lever is full forward , this is the initial setting .
Re: Edelbrock carb & kickdown throttle cable ant right??? [Re: JohnRR] #1214318
05/06/12 02:07 AM
05/06/12 02:07 AM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
thanks everbody for the pics, they helped, I just now got to keep adjusten on the kickdown to get the passing gear to work!... Got the throttle close to full throttle, I had to move the throttle cable back as far as I could to wear I steel could get the bracket tighten, now it likes very little getting full throttle!
