Re: Edelbrock carb & kickdown throttle cable ant right???
[Re: Hoop]
#1214288
04/11/12 08:34 PM
04/11/12 08:34 PM
Posts: 533 North Dakota
440abody
North Dakota
There are a couple of ways to approach this. One: it looks like you have a factory kick-down set up. Find yourself a factory service manual and adjust the linkage properly. But the linkage on the transmisson, and the carb need to have the proper throw ratio to be able to work together. If you have a lever on the transmission from a van, and the one from your a-body on the carb for example the throw ratio will not be correct, and getting it to work can be a real challenge. Or option two:Call Bouchillion Performance and order their kick-down kit and fix the problem for good.
73 Dart Swinger 440/727 8.75 w/3.55's 34 Ford 3w coupe with a soon to be 1958 392HEMI!
[Re: Hoop]
#1214297
04/13/12 03:19 PM
04/13/12 03:19 PM
Posts: 3,908 Oregon
hooziewhatsit
Yep, you'll want to get the correct edelbrock adapter. And, the slot in the kickdown MUST be held against the throttle studs at all times (by that long spring). If you have a gap there right now, that's your problem. When you push the throttle open, the lever must move immediately with it. The long slot is so if the kickdown linkage binds up, the throttle can still close (before things get exciting ). When I did my 4bbl conversion I had to extend the linkage about an inch so I had enough adjustment to keep it against the throttle stud.
[Re: Hoop]
#1214298
04/13/12 03:46 PM
04/13/12 03:46 PM
Challenger 1
Cincinnati, Ohio
Challenger 1, I don't know if johnRR or who broght up one of my old post from last year, but this is the new one!
I did not look at the dates, my bad. I hope you get it squared away this time.
[Re: Hoop]
#1214299
04/13/12 04:52 PM
04/13/12 04:52 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
My edelbrock kickdown & throttle cable stell ant right, if I drive with a lead foot, it douse fine, but if I pull out slow, it don't seem too smooth, so I would like to see some pics of how you guys with a-bodys have got your kickdown & throttle cable set up!
hears a pic of how mine is set up!
You still never install the ebrock adapter bracket , it's never going to be right without it , the spot you have it is higher than stock and the ratio for the trans lever movement is wrong .
[Re: JohnRR]
#1214301
04/13/12 07:46 PM
04/13/12 07:46 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
It may be the "wrong" way to do it, but when I installed my 4 barrel I just bent the original throttle and kickdown bracket until the throttle cable aligned right and bought a 2 dollar coupler nut and cut the head off of a bolt to extend the kickdown rod. Edelbrock sells the latter piece as some kind of an adapter for $15, mine looks exactly the same.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
[Re: bboogieart]
#1214305
04/14/12 04:19 PM
04/14/12 04:19 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
you guys need to quit showing him non-A body setups
