bleeding master cylinder question #1213921
04/10/12 11:27 PM
04/10/12 11:27 PM
middleburg,fl
barryv Offline OP
barryv  Offline OP
middleburg,fl
hi, i removed power booster and master cylinderfrom my 70 roadrunner.can i bleed master cylinder when i install it back on firewall. i dont have a work bench or vise to bleed the master cylinder the way it is usually done.thanks for the help
Re: bleeding master cylinder question [Re: barryv] #1213922
04/10/12 11:32 PM
04/10/12 11:32 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Sure, just run short tubes from the ports back into the reservoirs.
It's Swifty! Swifty, you toad sucker!
Re: bleeding master cylinder question [Re: zrxkawboy] #1213923
04/11/12 11:36 PM
04/11/12 11:36 PM
middleburg,fl
barryv Offline OP
barryv  Offline OP
middleburg,fl
thanks
Re: bleeding master cylinder question [Re: barryv] #1213924
04/11/12 11:43 PM
04/11/12 11:43 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
No problem. Actually, that's how I always like to "bench bleed" a MC. I'm going to bolt it on the car anyway, so it just seems easier to bleed it once it's bolted on.
Re: bleeding master cylinder question [Re: barryv] #1213925
04/12/12 11:04 AM
04/12/12 11:04 AM
loop a large towel under the M/C to catch any brake fluid
Re: bleeding master cylinder question [Re: RapidRobert] #1213926
04/12/12 11:09 PM
04/12/12 11:09 PM
middleburg,fl
barryv Offline OP
barryv  Offline OP
middleburg,fl
thanks again
