Re: bleeding master cylinder question
[Re: barryv]
#1213922
04/10/12 11:32 PM
04/10/12 11:32 PM
Posts: 905 SD
zrxkawboy
SD
Sure, just run short tubes from the ports back into the reservoirs.
It's Swifty! Swifty, you toad sucker!
[Re: barryv]
#1213924
04/11/12 11:43 PM
04/11/12 11:43 PM
Posts: 905 SD
zrxkawboy
SD
No problem. Actually, that's how I always like to "bench bleed" a MC. I'm going to bolt it on the car anyway, so it just seems easier to bleed it once it's bolted on.
[Re: barryv]
#1213925
04/12/12 11:04 AM
04/12/12 11:04 AM
RapidRobert
loop a large towel under the M/C to catch any brake fluid
