AAR master cylinder #1213784
04/10/12 08:30 PM
04/10/12 08:30 PM
Minnesota
goat432 Offline OP
goat432  Offline OP
Minnesota
I see a lot if differences in master cylinder appearance on even so called high dollar restorations. Some appear bare metal with plated lid & others I see are all black like the booster. Are both considered correct?
Re: AAR master cylinder [Re: goat432] #1213785
04/10/12 08:39 PM
04/10/12 08:39 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
You see a lot of different master cylinders and a lot of different appearances on restored AAR and TA master cylinders, but there is only one correct master cylinder and one correct appearance. It has a casting number 2229171 and the entire assembly is painted black including the cap and bale wire.
Re: AAR master cylinder [Re: Mastershake340] #1213786
04/10/12 10:50 PM
04/10/12 10:50 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
like this
Re: AAR master cylinder [Re: shakerjoe] #1213787
04/10/12 10:52 PM
04/10/12 10:52 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
#2
Re: AAR master cylinder [Re: shakerjoe] #1213788
04/11/12 02:58 PM
04/11/12 02:58 PM
Minnesota
goat432 Offline OP
goat432  Offline OP
Minnesota
Thank you both for the help.
Re: AAR master cylinder [Re: Mastershake340] #1213789
04/25/12 06:58 PM
04/25/12 06:58 PM
SC
Southern Wolf Offline
SC
I see a so called untouched car on the Trans Am cuda site and the master cylinder is not black. Which is correct.I just cleaned mine, do i need to paint it now.
Re: AAR master cylinder [Re: Mastershake340] #1213790
04/25/12 09:22 PM
04/25/12 09:22 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
This is correct, even the vacuum fitting was painted as part of the assembly.
Re: AAR master cylinder [Re: Alaskan_TA] #1213791
04/25/12 09:32 PM
04/25/12 09:32 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The paint on the master cylinder especially did not wear well, even on low mile examples. Two photos of an original from a low mileage car;
Re: AAR master cylinder [Re: Alaskan_TA] #1213792
04/25/12 09:34 PM
04/25/12 09:34 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Underside, same MC;
Re: AAR master cylinder [Re: Alaskan_TA] #1213793
04/26/12 09:51 AM
04/26/12 09:51 AM
SC
SC
THANKS
