Re: Hot tank a good 8.75 pumpkin, Y or N?
[Re: ahy]
#1213780
04/10/12 09:10 PM
04/10/12 09:10 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I agree, hot tank the whole thing? no.
what I have done though, is to use a parts washer with mineral spirits to clean the whole thing, inside and out, using a wire brush.
finished product was a perfectly clean, and bone dry differential on the inside, minor surface rust on the outside.
after I use air to blow it dry, I sprayed everything inside down with WD40 immediately before anything started to flash rust. then, I squirted 30 weight oil straight into the bearings before reassmbly. once installed, I degreased the outside again with oil, wax, grease remover, and painted it.
but, again, this was on a mid-50s Packard with a standard open diff.
I don't know what parts washer solvent may do to the clutches in your sure grip.
**Photobucket sucks**
Re: Hot tank a good 8.75 pumpkin, Y or N? *DELETED*
[Re: Challenger 1]
#1213782
04/11/12 09:43 AM
04/11/12 09:43 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Post deleted by 340SHORTY
I am truckless..
