BB & Hemi Flex plates #1213210
04/09/12 08:00 PM
04/09/12 08:00 PM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
I have some flex plates laying around and wanted to clarify what they were suited to.
I have two 8 bolt neutral balance flexplates, one is a B&M and the other is a Mopar Performance unit.
Are the Hemi and BBM 8 bolt flanges exactly the same?
The other flex plate is a B&M unit, it's a big block external balance unit. That is for a cast crank 440 I am assuming?
Thanks in advance!
Alan Jones
Re: BB & Hemi Flex plates [Re: LA360] #1213211
04/09/12 08:09 PM
04/09/12 08:09 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Yes the 8 bolt fits 2nd gen hemis and big blocks that either have 2nd gen cranks or current 8 bolt aftermarket cranks designed to fit in B/RB blocks.
Mopar had 2 external balance big block weights , the 70-73 440 4bbl HP/70-72 6pk and then the Cast crank engines which are different so you need to know which that is .
Re: BB & Hemi Flex plates [Re: JohnRR] #1213212
04/10/12 06:33 AM
04/10/12 06:33 AM
LA360 Offline OP
LA360  Offline OP
The B&M flex plates have a part number, so I can look up their application.
Thanks for the reply John
Alan Jones
